I need to expose the usb port on an arduino pro micro to the outside of a project box. I've been looking for some sort of panel mount extension cable, and all I've been able to find are ones that look like this:
I'm confused about why the middle of the plug is recessed like that; isn't that going to result in the usb port itself sitting behind the panel, rather than flush with the panel? I haven't been able to find a picture of one of these in use anywhere to verify.
If it matters, the case to which I'll be mounting this is a thin tin (formally it held pirate not-actually-band-aids; think an altoids tin, but slightly bigger).
larsks
  • 268
  • It's not clear that the face of the connector isn't flush with the mounting surfaces. But regardless, this is a question you'd have to pursue with the manufacturer. The standard advice here is "no data sheet, no sale" - in this case it's particularly the *mechanical drawing* you need. – Chris Stratton Sep 14 '20 at 03:18
  • that connector shell is fairly large, compared to the size of the Altoids tin ... you can put the wide part on the outside of the tin – jsotola Sep 14 '20 at 03:19
  • Right, as I said, not actually an altoids tin: larger box, but similar thickness of material. – larsks Sep 14 '20 at 03:19
    take a closer look at the picture ... the plug is not recessed ... shave the ears down so that they are flush with the recessed area if you like – jsotola Sep 14 '20 at 03:21
  • I see that, but it looks like it's flush with the non-recessed ends of the connector. I would expect it to be slightly proud so that it would extend into/through the panel into which it was mounted. – larsks Sep 14 '20 at 03:22
    It looks like it was designed to fit the same cutout that you would use for a DE-9 (or HD15) D-sub connector. – Dave Tweed Sep 14 '20 at 03:26
0 Answers0
