I have a 100 Mhz clock and I need a 0.5 Khz clock. So I wrote this code:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
entity clkdiv is
    Port ( clk : in STD_LOGIC;
           reset : in STD_LOGIC;
           clkout : out STD_LOGIC);
end clkdiv;
architecture Behavioral of clkdiv is
signal temporal : std_logic := '0';
signal counter : integer range 0 to 99999 := 0;
begin
process (reset, clk) begin
if (reset = '1') then
       temporal <= '0';
       counter  <= 0;
elsif rising_edge(clk) then
    if (counter = 99999) then
        temporal <= not temporal;
        counter <= 0;
    else
        counter <= counter + 1;
    end if;
end if;
end process;
clkout <= temporal;
end Behavioral;
And testbench for it:
library IEEE;
-- Uncomment the following library declaration if using
-- arithmetic functions with Signed or Unsigned values
--use IEEE.NUMERIC_STD.ALL;
entity testbench is
end testbench;
architecture Behavioral of testbench is
component clkdiv
           end component;
signal clk : std_logic := '0';
signal reset : std_logic := '0';
signal clkout : std_logic;
constant clk_in_t : time := 10 ns;
begin
uut : clkdiv port map (
    clk => clk,
    reset => reset,
    clkout => clkout);
    process
    begin
    clk <= '0';
    wait for clk_in_t / 2;
    clk <= '1';
    end process;
process
    begin
    reset <='1';
    wait for 100 ns;
    reset <= '0';
    wait;
    end process;
end;
However, testbench results are like that: enter image description here
Can anyone tell me what's wrong? Thank you all.
    What did you expect to happen and how is the result different? – The Photon Sep 10 '20 at 17:54
  • @ThePhoton well i expected a normal clock which has a frequency of 0.5 khz but the output does not work like a clock at all. – dubistweltmeister Sep 10 '20 at 17:56
    A 0.5 kHz clock changes state once every millisecond, but you only ran the simulation for 1 microsecond. – The Photon Sep 10 '20 at 17:58
  • @ThePhoton yea i realized that. how can i run the simulation for much longer time? – dubistweltmeister Sep 10 '20 at 18:01
    Just change the time limit in the command that runs the simulation. – The Photon Sep 10 '20 at 18:01
    But it might be quicker to change your design to generate, say, a 2 MHz clock, and verify your general approach before doing the final design. – The Photon Sep 10 '20 at 18:02
  • @ThePhoton thank you. i'll try it that way – dubistweltmeister Sep 10 '20 at 18:04
    You do realise you can look at "counter" in the wave window to see if it's counting, right? –  Sep 10 '20 at 19:09
  • How are you running the simulation. What command are you using? – mrbean Sep 10 '20 at 19:48
    This is bad practice. You do not divide clocks in logic fabric. What you do is periodically trigger things using a clock enable instead and have it running off the real clock. If you truly need a lower frequency clock then use the FPGA's PLL. – DKNguyen Sep 10 '20 at 21:32
    To echo DKN, it's never a good idea to generate a low speed clock in FPGA. It looks easy, but it leads to all sorts of timing problems. Clock **everything** from the same system-wide high speed clock, and generate a 500 Hz **clock enable** signal to feed to your low speed logic, to tell it when to change, and when not to. – Neil_UK Sep 10 '20 at 21:49
    To further clarify the important point by Neil_UK and @DKNguyen : you only "truly" need that clock if the logic should run at a lower speed for physical reasons (to fit a large blob of logic within a generous cycle) not functional reasons (to do something once in a while). Both goals can be accomplished with a clock enable, and adjustments to your timing analysis. If ALL your logic & IO runs at 500Hz and ALL your logic fits in a 100MHz design, then this could work. – P2000 Sep 21 '20 at 20:39
I've rounded up all the good advice from the comments into an answer.
Clock Strobe
Generates a slower strobe from a faster clock.
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity ClockStrobe is
    generic
        CLOCK_PERIOD : time := 20 ns;
        STROBE_PERIOD: time := 2 ms
    port
        reset : in std_logic;
        clock : in std_logic;
        strobe: out std_logic
end entity;
architecture V1 of ClockStrobe is
    constant MAX_COUNT: natural := STROBE_PERIOD / CLOCK_PERIOD - 1;
    signal counter: natural range 0 to MAX_COUNT := 0;  -- Specify the range to reduce number of bits that are synthesised.
begin
    process(all)
    begin
        if reset then
            strobe <= '0';
            counter <= 0;
        elsif rising_edge(clock) then
            if counter = MAX_COUNT then
                strobe <= '1';
                counter <= 0;
            else
                strobe <= '0';
            end if;
        end if;
    end process;
end architecture;
Test Bench
library ieee;
use ieee.math_real.all;
entity ClockStrobe_TB is
end;
architecture V1 of ClockStrobe_TB is
    constant clock_period : time := 10 ns;
    constant STROBE_PERIOD: time := 2 ms;
    -- constant CLOCK_PERIOD : time := 10 ns;
    -- constant STROBE_PERIOD: time := 40 ns;
    signal halt_sys_clock: boolean := false;
    signal reset: std_logic := '0';
    signal clock: std_logic := '0';
    signal strobe: std_logic;
    component ClockStrobe is
        generic
        port
    end component;
begin
    ClockGenerator:
    process
    begin
        while not halt_sys_clock loop
            clock <= not clock;
            wait for CLOCK_PERIOD / 2.0;
        end loop;
        wait;
    end process ClockGenerator;
    Stimulus:
    process
    begin
        -- Do reset.
        wait for CLOCK_PERIOD / 4;
        reset <= '1';
        wait for CLOCK_PERIOD / 2;
        reset <= '0';
        -- Wait for a couple of strobes.
        wait for 2.1 * STROBE_PERIOD;
        -- Halt simulation.
        halt_sys_clock <= true;
        wait;
    end process;
    CS:
        ClockStrobe
        generic map
            CLOCK_PERIOD => CLOCK_PERIOD,
            STROBE_PERIOD => STROBE_PERIOD
        port map
            reset => reset,
            clock => clock,
            strobe => strobe
end architecture;
Simulation Results
Clock Strobe Simulation Results
Figure 1 – Clock strobe simulation results: 100 MHz clock; 500 Hz strobe.
Using the Clock Strobe
And here is how to use the clock strobe for slow logic.
library ieee;
entity SlowLogic is
    port
        strobe: in std_logic
        -- Slow inputs and outputs here.
end entity;
architecture V1 of SlowLogic is
begin
    process(all)
    begin
        if reset then
            -- Reset slow outputs, etc.
            if strobe then
                -- Do slow logic on inputs and outputs.
            end if;
        end if;
    end process;
end architecture;
tim
  • 850
    Perhaps a remark: without any additional timing constraints for synthesis, the "slow logic" updates at the slow clock but is synthesized at 100MHz. – P2000 Sep 21 '20 at 20:48
