13
This LED drive module exploded last night, as the result of an earthed (grounded) screw touching a capacitor leg. The breaker (fuse box) tripped, of course, due to earth leakage. That bit makes sense.
What I don't get is why there was a massive bang, a flash, tracks blown off the board and soot all over the place. Of course, this is not unusual in mains power faults, but in this particular case, the short appears to have been between neutral and ground.
I like to think I have a fairly good understanding of electricity, but given that neutral is connected to ground at the fuse box, I don't see how a large enough voltage should develop between the two (in this situation) to cause such devastation.
For bonus points, can you think of any good reason that a completely different piece of equipment (an electronic HDMI switchbox) should now be completely nonfunctional after the above incident? It was powered via an isolated wall-wart, and was completely unrelated to the device that exploded, other than being located within two feet of it.
Photos and (best as I can tell) the correct circuit diagram follow.
diagram
photo 1
photo 2
Sod Almighty
  • 1,295
    Oh, Soot Almighty! – Marcus Müller Sep 09 '20 at 19:10
  • "can you think of any good reason that a completely different piece of equipment (an electronic HDMI switchbox) should now be completely nonfunctional after the above incident" Blown fuse? – Lundin Sep 10 '20 at 12:47
  • Nope. The power light lights up (so I guess it depends how you define "completely nonfunctional" I suppose) but nothing operates on the unit. – Sod Almighty Sep 10 '20 at 19:20
The bottom of C2 is not ground. It is connected to the live input by the diodes in the bridge rectifier on every AC cycle.
During the negative half-cycle of the incoming AC waveform, the Neutral wire is positive relative to the live wire.
The two grey diodes in the diagram below will be conducting for this half cycle, the other two conduct during the other half cycle.
The Neutral is connected to the protective ground at the circuit breaker panel (depending upon the local electrical codes). So AC power earth and the neutral line are effectively the same point electrically.
The neutral wire (or earth) where the short circuit occurred will have a voltage (up to ~300V) relative to the bottom pin of the capacitor.
The screw caused a short circuit between these two points and caused a large current to flow along the path of the red arrows causing the upper-left blue diode to be destroyed.
During the other half cycle of the input waveform, the voltage between the two shorted points will only be ~0.7V across the already conducting lower-left grey diode. No damage will result as a result of the short-circuit.
You should always be very careful when testing or inspecting a device such as this - there is no point that is ground.
If for example, you connect a grounded instrument such as a scope you can cause a similar destructive short circuit.
It is common for the power supplies to be organized similarly, computers, TVs, DVD players etc.
Kevin White
  • 32,097
  • 47
  • 74
  • Ah. So you mean during those parts of the waveform that live is negative, there is a 240V potential difference between the bottom of the cap and earth, the cap being negative with respect to earth? – Sod Almighty Sep 09 '20 at 20:18
  • Actually it is worse than that and for parts of the cycle it is more than 300V for a 220V RMS input. – Kevin White Sep 09 '20 at 21:14
  • I've just realised your answer - while interesting - doesn't explain the entire situation. If you look at the photo, it's the *neutral leg* of the rectifier that blew off. If the short was between earth and live (during the negative part of the cycle), why did we lose the neutral leg of the rectifier while the live leg survived? – Sod Almighty Sep 10 '20 at 19:37
    @SodAlmighty, in an energized AC circuit, there is no "line" or "neutral" wire. There are only "live" and "live" wires. It's only when you've got a gap in the circuit that it matters which wire is being driven by the generator. – Mark Sep 10 '20 at 20:40
  • @SodAlmighty - I've added more detail to my answer. – Kevin White Sep 10 '20 at 20:42
  • I see what you're saying - both live and neutral source and sink current - but I still don't see why the N leg of the rectifier blew off in this case. There *is* a difference between live and neutral: *neutral is connected to earth at the fuse box!* That leg of the rectifier should only carry current when the earth fault (lower leg of the cap) happens to be positive with respect to N. Earth should never be positive with respect to neutral. – Sod Almighty Sep 10 '20 at 22:03
  • There wasn't an earth fault at the rectifier, so the arrow you have drawn linking it to the cap boom is incorrect. There was *only one earth fault*, and that was at the cap. The rectifier "boom" was *caused* somehow by the earth fault at the cap, and I don't understand why. – Sod Almighty Sep 10 '20 at 22:05
  • "The screw caused a short circuit between these two points" no, it did not. The screw caused a short between EARTH and the cathode of the capacitor. The rectifier leg exploded all by itself, for no apparent reason. Hence my confusion. – Sod Almighty Sep 10 '20 at 22:11
  • @SodAlmighty - so I incorrectly interpreted your diagram showing the two points that shorted? It was from ground to the bottom of C2? Is that correct? – Kevin White Sep 10 '20 at 23:52
  • Correct. I was illustrating the bits that died, not the bits that shorted together. I apologise if I was unclear. You can see in the photos that the capacitor leg is now broken, and the rectifier leg is just.......gone. – Sod Almighty Sep 11 '20 at 01:12
  • @SodAlmighty - But it was a grounded screw that contacted C2 - is that correct? – Kevin White Sep 11 '20 at 01:28
  • It was, yes. I grounded the chassis for safety, but accidentally screwed it into the capacitor... :/ – Sod Almighty Sep 11 '20 at 01:33
15
you can call it ground, but it's not actually ground. It's actuallty the negative output of the bridge rectifier.
That short circuit allows a large current to flow in D4
Boom!
Regarding the second part of the question, the now broken HDMI electronic box, my first thought would be that it is a totally unrelated event, but discovered at a later time. The only other plausible hypothesis concerns an overvoltage due to the transient following the intervention of the circuit breaker or the subsequent reset, but it's very unlikely.
DrSurfer
  • I wonder if the short caused a momentary, and localised change to the AC waveform in the HDMI's wallwart - presumably not the greatest quality PSU - which caused it to fail, or blow a fuse or whatever...? Still seems a bit of a reach though. – Ralph Bolton Sep 10 '20 at 16:18
  • It was discovered immediately, as I use the HDMI switch all day every day. And it's not a fuse issue. Power is reaching the unit (power light is illuminated) but no functionality of any kind. No status lights, no HDMI throughput. And, interestingly, the wall-wart power supply still works, and will power my *other* HDMI switchbox. Which also still works... – Sod Almighty Sep 10 '20 at 19:23
  • I absolutely believe you about the time of discovery. These effect of transients are sometimes very chaotic. Without some circuit analysis, we can't even know if the energy surge that broke your apparatus traveled along wires or in the air. – DrSurfer Sep 11 '20 at 09:48
  • First, the damaged HDMI Box could easily be damaged by the triggering of the fuse. If any circuit after the fuse has stored energy or the fuse triggered too slow (fault), it will cause such issues. and most (cheep) consumer parts will not have sufficient surge protection. back to number one, the blown LED drive module - the contact with earth might not have been perfect (higher resistance), so the Fuse was triggered by time not by peak current. Or it first triggered after the burnings (coal is a better conductor). – schnedan Sep 11 '20 at 20:07
-1
Because it was probably plunged in the 220VAC socket and you can twist around. How do you know that L was connected to line and N to neutral?
Marko Buršič
  • 23,562
    But a circuit like this would bang the same way, whatever was the Live and Neutral connection, doesn't matter if the plug was twisted or not. – mguima Sep 09 '20 at 19:05
  • @mguima Yes you are correct. The cap potential is cca +160 VDC or -160 VDC whatever position you plug in. Make your answer. – Marko Buršič Sep 09 '20 at 19:09
    @MarkoBuršič because I live in the UK, where matters of electrical safety are taken seriously. It is physically impossible to plug appliances in backwards. – Sod Almighty Sep 09 '20 at 20:20
    @SodAlmighty If it weren't for The Channel, my country would neighbor yours. We have different plugs, but ours are also impossible to plug in backwards. But... that has nothing to do with reverse polarity. Because with AC... there is no polarity. Flipping the L and N in an appliance (important distinction! ), will not affect its workings whatsoever. So in your schematic, L and N could have well been reversed without you knowing it. It didn't matter anyhow. relative to each other, they would have been the same. – Opifex Sep 10 '20 at 06:55
    -1 Doesn't make any sense for the circuit in question. The short wasn't to ground, but to the negative DC rail. – TooTea Sep 10 '20 at 10:11
  • @Opifex you mean the lines might have been flipped *inside* the appliance, and I wouldn't have known? 'fraid not. I wired it myself - and incidentally, *added* the earth connection to this unsafe non-compliant piece of Chinese crap. It was my error that caused the bang, but also my forethought in earthing the metal chassis that potentially saved my life. – Sod Almighty Sep 10 '20 at 19:26
  • @SodAlmighty Earth connection? Please don't tell me you wired N to the PE? – Opifex Sep 10 '20 at 20:16
  • There seems to be some confusion here. The device was wired correctly, except came from China with the metal chassis not earthed, because the Chinese are perfectly comfortable with the risk of fatal electrocution. I added an earth; and it's a good job I did, because when I reassembled the unit, I inadvertently created a short between the capacitor and the chassis. Hence the boom. – Sod Almighty Sep 10 '20 at 22:14
  • And no, I didn't do stupid things like wire N to E or any such nonsense. My only error was using screws that were too long, which bit into the (heatshrinked for safety) circuit and caused a short. – Sod Almighty Sep 10 '20 at 22:16
