Question
Is it ok to charge a battery with TP4056 while using it, if the current consumption of the load isn't higher than the charging current of TP4056? and if not why?
Trying:
- To have a 200mah Li-ion Battery (502025)
- Charging it at 130mah (TP4056 + Rprog[10kohm])
- While using it with a load which consums about 30-60 mah
(Extra question: how much 130mah of charging would effect the battery in the long term)
Outro
if you have any other idea on how i could charge that li-ion with 30% of its current while being able to use it at the same time i would be really happy to know about it, just please have in mind that i am kinda noob with electronics [...]
Thanks in Advance for any Help
(PS. i think i've read somewhere that TP4056 is not meant to be used as a load driver for some reason..)
