I am implementing power amp. with 16-QAM. Because of issue on power consumption, I am using time division duplex (TDD). By TDD, the power amp. turns off if the carrier wave is not needed and vice versa.
As represented in the figure, PLL makes 4 output signals P0~P270 with 90 degrees difference each. When PA turns off, the switch between PLL and PA disables to block AC signals.
Here is the issue:
There exist some overshoots when the power amp. turns on by TDD.
Does anyone experienced this overshoot when the transmitter turns on? What would be the reason?
enter image description hereenter image description here
  • You need to show the exact and precise circuit you have used and not some prettified version because how can anyone say what happens without full details? – Andy aka Sep 02 '20 at 19:03
    Check the supply rail with TX off and turning on. How well is it regulated? –  Sep 02 '20 at 19:19
  • Can you capture a waveform of those "overshoots" and add it to your question? Can you share your exact circuit? – eeintech Sep 04 '20 at 03:13
0 Answers0
