I want to simplify the following boolean function:
$$Z=A\bar B \bar{C_i} + \bar A B \bar{C_i} + \bar A\bar B {C_i} + A B {C_i}$$
Here's my attempt:
\begin{align} Z &= A\bar B \bar{C_i} + \bar A B \bar{C_i} + \bar A\bar B {C_i} + A B {C_i} \\ & = \bar{C_i}(A \bar B + \bar A B) + C_i(\bar A \bar B + AB) \\ & = \bar C_i(A \oplus B) + C_i(A \equiv B) \end{align}
I thought this was the end of it but in my textbook it continues and has: \begin{align} Z &= A\bar B \bar{C_i} + \bar A B \bar{C_i} + \bar A\bar B {C_i} + A B {C_i} \\ & = \bar{C_i}(A \bar B + \bar A B) + C_i(\bar A \bar B + AB) \\ & = \bar C_i(A \oplus B) + C_i(A \equiv B) \\ & = A \oplus B \oplus C_i \\ & = A \equiv B \equiv C_i \end{align}
I'm confused about what happened between the third and fourth step. What boolean algebra rules are being used here?
Ski Mask
  • 143
  • You need a double dollar sign for your title. – DKNguyen Sep 02 '20 at 19:34
    $$A \equiv B$$ is the same as NOT $${(A \oplus B)}$$ (sorry not very good at formulas) – jcaron Sep 02 '20 at 21:05
    @jcaron Yes but I'm trying to figure out why $$\bar C_i(A \oplus B) + C_i(A \equiv B)=A \oplus B \oplus C_i$$. – Ski Mask Sep 03 '20 at 12:02
  • It's another instance of (X AND NOT Y) OR (NOT X AND Y) = X XOR Y, with X being Ci here and Y being A XOR B. – jcaron Sep 03 '20 at 12:07
  • Wouldn't it be (NOT X AND Y) OR (X AND Y)? – Ski Mask Sep 03 '20 at 12:44
    By \$X\equiv Y \$, what do you mean exactly? I've never seen this notation so far. – edmz Sep 04 '20 at 19:10
    Seems like $$A\equiv B$$ is the same as $$\overline{(A\oplus B)}$$. In that case, $$\begin{align} Z&=\overline{C_i} (A \oplus B) + C_i (A\equiv B)\\ &=\overline{C_i} (A \oplus B) + C_i\overline{(A \oplus B)} \\ &= C_i \oplus (A\oplus B)\\ &=A\oplus B\oplus C_i \end{align}$$ – cjferes Sep 04 '20 at 21:50
  • Are there any solver tools that can brute-force (or use other heuristics to obtain) a solution to this sort of problem? – Sean Sep 05 '20 at 22:04
  • @Sean Unfortunately this is from a written question from a past paper. So I have to show all my working out and the laws that I used. – Ski Mask Sep 07 '20 at 11:19
  • @Ski Mask, I was actually asking out of my own interest, and I'm still interested in the answer! – Sean Sep 07 '20 at 17:57
  • Brute force would be cool. I wonder if some optimization algorithm could be found for minimizing the number of operators used. Some kind of derivative for this problem? Perhaps AI? – sergiu reznicencu Sep 07 '20 at 18:49
  • Or better. Just assume the final result contains all inputs used once with one operator in between. This is very much possible – sergiu reznicencu Sep 07 '20 at 18:51
Observe that
\begin{align}\overline{\overline{A} \cdot\overline{B} + A\cdot B} = \overline{(\overline{A}\cdot\overline{B})}\cdot\overline{(A \cdot B)} = (A + B)\cdot(\overline{A}+\overline{B}) = A \cdot\overline{B} + \overline{A}\cdot B \end{align}
Hence
Shashank V M
  • 2,279
  • 47
    Ah I see. I made the mistake of taking $$A \equiv B = A \oplus B$$ and not $$\lnot{(A \oplus B)}$$ – Ski Mask Sep 07 '20 at 11:18
When in doubt about booleans, just build a truth table.
Truth tables for XOR (\$\oplus\$):
   | 0 | 1
 0 | 0 | 1
 1 | 1 | 0
For "is equal to" (\$\equiv\$):
   | 0 | 1
 0 | 1 | 0
 1 | 0 | 1
As you can see \$A \equiv B\$ gives just the opposite result of \$A \oplus B\$ (the result is 1 for the first when it is 0 for the second, and vice-versa). This means that:
$$A \equiv B = \overline{A \oplus B}$$
You used several times the identity $$X\overline{Y} + \overline{X}Y = X \oplus Y$$
This means: If (X is true AND Y is false) OR (if X is false and Y is true) is the same as either X or Y is true, but not both, which is quite straightforward.
So now you get to this equation:
$$\overline{C_i}(A \oplus B) + C_i(A \equiv B) \\$$
Since \$A \equiv B\$ can be written as \$\overline{A \oplus B}\$, you can rewrite it to:
$$\overline{C_i}(A \oplus B) + C_i(\overline{A \oplus B}) \\$$
Which is a form of \$X\overline{Y} + \overline{X}Y\$, with \$X = C_i\$ and \$Y = A \oplus B\$.
So it can then be rewritten to:
$$C_i \oplus (A \oplus B)$$
As all these boolean operators are commutative, this be be rewritten as:
$$A \oplus B \oplus C_i$$
jcaron
  • 1,720
First, plus is an unusual operator for bool equations Wikipedia. I assumed you referencing a OR
formula
With this assumtion I came to the result: no further reduction possible. For This I used a Karnaugh map
https://en.wikipedia.org/wiki/Karnaugh_map
schnedan
  • 2,538
    [Leibniz used + for inclusive OR](https://www.hf.uio.no/ifikk/forskning/publikasjoner/tidsskrifter/njpl/vol2no1/history.pdf) and Boole used it too, so it's been around for over 300 years. Nowadays, it's more usual to use + for OR and ⊕ for XOR because it's far more readable. See discussion [here](https://electronics.stackexchange.com/questions/131317/why-is-the-sign-commonly-used-as-logic-or-operator). Plus, there's far more to reduction than Karnaugh Maps, e.g. De Morgan's Laws. Don't believe everything you read on Wikipedia. – tim Sep 07 '20 at 12:30
  • I only quote wikipedia if it states things I know to be correct an are also in my books... I work in electronics for 25 years now, and never saw a plus for OR from any professional... – schnedan Sep 07 '20 at 12:38
  • also as you can see in the formula als well as in the Karnaugh_map there are always 2 of 3 elements different in any case and there is no 2 Element term which can be reused without modification (like invert) in an other therm. So if there is a further reduction I like to learn how, but I don't see any – schnedan Sep 07 '20 at 12:47
  • Things like De Morgan's Laws, to my knowledge are good for 5 or more variables where Karnaugh_maps start to be of no use. But if you can apply a simple scheme like Karnaugh_map its a valid measure to do so. – schnedan Sep 07 '20 at 12:54
  • As you can see, a 4-input OR gate with 3 NOT gates had been reduced to a 3-input XOR gate. The + and ⊕ signs are standard teaching in schools, colleges and universities around the world. Are you trolling? – tim Sep 07 '20 at 12:57
  • No, but people which think they know what is taught in other parts of the world do – schnedan Sep 07 '20 at 13:05
  • Well, a quick Google for [boolean algebra university slides](https://www.google.com/search?q=boolean+algebra+university+slides) sorted that one out. – tim Sep 07 '20 at 13:15
  • @schnedan (-1) The question is clearly involving the ⊕ and ≡ operators, which you don't get from simply grouping on a Karnaugh map. Your beloved [wikipedia](https://en.wikipedia.org/wiki/Exclusive_or) shows the disjunctive form of ⊕ as "x̅y+xy̅", which also wrecks your tangent about the plus operator. – mbedded Sep 08 '20 at 15:36
  • Well I don't see ⊕ and ≡ in the OP's formula plus these signs are just not common here - as well as + is not too. And its not my beloved wikipedia, I could also just scan a book I own for ~25 years with more or less the same content. Wikipedia is just more handy here. – schnedan Sep 08 '20 at 16:43
