I am trying to create a counter that starts counting when a start signal goes from 0 to 1. Then, I want the counter to keep counting until both the start and stop signal are 1. Once both signals are 1 the counter should reset to 0.
I am confident that the reason my counter does not reset is because of the "else if (start && stop)" statement.
Thanks for the help!
Here is my code:
module count2     (
out  ,   // output of counter
start ,   // start pulse
stop,     // stop pulse
clk  ,  // clock input
reset    // reset input
input start, stop, clk, reset;
output out;
reg [7:0] out;
reg [7:0] counter;
always @ (posedge clk)
if (reset)
begin
    counter <= 8'b0;
end
else if (start)
    counter <= counter + 1;
begin
    counter <= 8'b0;
end
endmodule
Here is my tesetbench:
`timescale 1ns/100ps
module count2_tb;
// parameter SYSCLK_PERIOD = 20;// 50MHZ
reg clk_1;
reg start_1;
reg stop_1;
reg reset_1;
wire [7:0] out_1;
initial
begin
    clk_1 = 1'b0;
    start_1 = 1'b0;
    stop_1 = 1'b0;
    reset_1 = 1'b1;
    #20;
    reset_1 = 1'b0;
    #20;
    start_1 = 1'b1;
    #50;
    stop_1 = 1'b1;
    #50;
    $stop;
end
// Clock Driver
always
    #5 clk_1 = ~clk_1;
// Instantiate Unit Under Test:  counter
count2 count2_0 (
    // Inputs
    .start(start_1),
    .stop(stop_1),
    .clk(clk_1),
    .reset(reset_1),
    // Outputs
    .out( out_1 )
endmodule
Here is my waveform output from ModelSim:
yer
  • 67
The conditions in an if-else if chain are evaluated sequentially, and once one of them matches, the other ones will not be checked. So when you have:
else if (start)
it sees that start is 1, and runs the counter + 1 assignment. It never checks if stop is also 1.
To fix it, you have 2 options:
  • Reverse the order of the checks (check start && stop before checking start alone), or
  • Change the first condition so that it is false when stop is 1, like if (start && !stop)
Justin
  • 5,944
