I am a student and trying to understand the MOS transistor.
So I have simulated the transfer curve of a MOS in Cadence and done a parametric sweep for WL (500n, 1000n).
Here you can see the plot sqrt of the transfer curve Vgs/Id. (Level 1 Model) SQRT of Vgs/Id Plot
If I change to a level 49 model in Cadence the curve is no longer quadratic. There are two effects I can see in the plot. First the curve rises exponentially/quadratic around the threshhold voltage and then it flattens out. Why is this so?
SQRT of Vgs/id Plot (level 49 model)
Diemex
  • 159
    The real world is not defined by perfect mathematical relationships, but rather we use mathematical relationships to understand the real world. – StainlessSteelRat Aug 29 '20 at 17:28
The exponential behavior is known as subthreshold conduction and is seen when the MOSFET's channel is in weak inversion. In this mode of operation, diffusion current dominates (while in strong inversion, the device operation is best explained with drift current).
From an analog design standpoint, operating in this weak inversion regime allows for highly power-efficient design. In particular, \$g_m / I_D\$ (one particular figure of merit used in some designs) is quite good, as is the output impedance of the MOSFET. This allows for high gains to be realized with low current consumption.
With wide transistors operating in this weak inversion scheme, it is also possible to achieve good gain-bandwidth products under the assumption that output capacitive loading contributes the dominant pole (since the frequency of that pole is roughly modeled by \$G_m / (2\pi C_L)\$. This assumption is often valid when doing VLSI design.
The tradeoff is the speed of the transistor itself, as \$f_t\$ is relatively poor in this mode of operation. Once the input signal reaches a frequency of \$f_t\$, the transistor can no longer perform any meaningful amplification: to get 1 nA of sinusoidal small-signal current through the drain, the gate capacitance must be driven with that same amount of current to actually modulate the channel. This creates issues for higher-frequency signals, since the high transconductance achievable with wide transistors begins to interact with the capacitances inherent to the transistor itself.
While I don't have exact numbers from any particular CMOS process which I am allowed to share, I can show this approximate chart that adequately conveys the rough behavior of these two figures of merit as the inversion coefficient changes.
Notice that as the transistor's channel is driven into weaker and weaker saturation, the transconductance efficiency tops out at some value, while the transit frequency drops further and further, into values as low as the kHz range in extreme situations.
In the processes that I worked with (mostly older mixed-signal CMOS, sub-micron but not anywhere near FinFET sizes), the typical values for gm/Id (transcondutance efficiency) are in the 20s to 30s in weak inversion. This comes from the fact that the weak inversion drain current in a MOSFET is like that of a BJT, but with a non-ideality factor \$n\$:
$$\begin{align} I_{bjt} &= I_0 e^{\frac{V_\pi}{V_t}}\\ I_{fet} &= I_0 e^{\frac{V_\pi}{n V_t}} \,\,\text{(for weak inversion only)} \end{align}$$
With some mathematical rearrangement, it can be shown that the transconductance efficiency in each case is \$\frac{1}{V_t}\$ and \$\frac{1}{nV_t}\$, respectively.
Ft can be over 10 GHz even in an older (larger than 100 nm) process.
nanofarad
  • 18,062
  • 47
  • 73
    I rarely use MOSFETs for anything other than switches and I've not needed to know, or learn about these details (or your generalized perspectives on them) before. I really appreciate this discussion you've offered. It provides me with some new thoughts that I believe I need to explore. Much appreciated and +1, of course! – jonk Aug 28 '20 at 22:21
    @jonk Happy to help! I'm glad that you enjoyed this answer's perspective. – nanofarad Aug 28 '20 at 22:42
  • Let me try that again... (I deleted my mistaken writing a moment ago.) You mentioned a particular figure of merit. For a BJT, \$g_m=\frac{I_C}{V_T}\$. So dividing that by \$I_C\$ yields about 40 for a BJT. What is considered "good" for a MOSFET, in cases where the MOSFET is operated in these highly power-efficient domains? – jonk Aug 28 '20 at 23:00
  • @jonk I've added some values based on my experience (which was on a CMOS process designed for a good balance between digital performance in strong inversion, and analog performance). I can imagine that a MOS process designed for analog performance above all else can achieve better transconductance efficiencies. – nanofarad Aug 28 '20 at 23:03
    Thanks! I see the values are crazy-close to BJTs. I didn't expect they could get that close! Appreciate the additions very much! You have made my electronics-day, today! – jonk Aug 28 '20 at 23:06
  • I would think another FOM is the gm/Ciss or gm/Coss ratio for GBW*k – Tony Stewart EE75 Aug 29 '20 at 13:20
  • @TonyStewart it is, there are a number of different figures that I presented to my students (as a TA, not prof) depending on the project. I chose to highlight the ones that we used most often for our designs, and which are very cleanly related to inversion coefficient. If I'm not mistaken, those parameters (FET's gm compared with FET's own capacitance) can be encompassed in the transit frequency, at least for a rough first-pass analysis. – nanofarad Aug 29 '20 at 14:12
    If I were to look for the fastest dI/dt , I would use my FOM. although I didnt need it , have done so in a scatter plot on all Digikey’s FET database which helps greatly in SMPS or half bridge choices. Which with an autofilter can also include cost / benefits. – Tony Stewart EE75 Aug 29 '20 at 14:13
The conductance exponential becomes linear when the current becomes limited by the bulk resistance from size and characteristic of the junction geometry.
This Vg/Vt ratio is sufficiently the RdsOn resistance dominates the linear value. Although the term saturated is opposite for technical reasons. .
RdsOn is rated at Vgs=>2 to >=2.5x Vt {or Vgs(th)} or some std. voltage like 5, 10 etc., where the bulk resistance of a FET dominates Ron and is linear, almost.
Yet Vt has a wide tolerance unlike Vbe. The std. old ones are 2~4V =Vt while the newer ones are <<1V
For BJT’s the supersaturated transistors are just superhigh hFE so when Ic/Ib=50 or less, and hFE is 500 to 2000 ($) so its a good switch with lower capacitance than FETs with Rce=Vol/Ic as the saturated bulk resistance which is pretty linear except for thermal effects. So instead of the usual Ic/Ib=10 for Vce=Vce(sat) the better ones are 20 to 50. This is tends to be around <10% of the best case linear hFE.
Remember that when the quadratic Ron vs Vgs goes less than the bulk series resistance, RdsOn is usually constant enough with power design margin so linear power dissipation except that in most cases RdsOn increases with temperature so it loses linearity.
  • My rule of thumb for low fixed Rdson or Ron is Vgs>=2 * Vt for the <=1V types
    • and Vgs>=2.5 * Vt for std Vt=2-4V types. But since there is a wide margin on Vt the RdsOn may say nominal in these ranges and use >3 *Vt for guaranteed min. RdsOn.
FWIW, the term quadratic describes something that pertains to squares. So when in doubt replace the word quadratic with exponential.
The SPICE level 1 model implements the simple FET theoretical (quadratic) characteristic. However this simplified model ignores some real-world effects in a FET
  1. Around the threshold voltage, the device conducts a small current that is exponentially dependent on the gate voltage. Thus, even for VGS < VTH, it will conduct (slightly). As VGS exceeds VTH, this weak inversion current 'dies out', and the simplified quadratically-dependent current flows.
  2. At larger currents (VGS >> VTH), the effects of source series resistance (internal to the FET) become noticeable, reducing the effective VGS that the channel sees, and making the current become lower than the square law values.
  3. Drain resistance can also become a contributor. This reduces the internal VDS of the FET, and because of either output impedance, or exiting saturation, the current will be lower than expected.
jp314
  • 18,395
