I am trying to simulate a basic inverter circuit in LTspice. For some reason I am unable to obtain 48V peak to peak across the resistor R1 which only shows about 6Vp-p (indicated by the blue square wave). V(first) and V(second) are the pulse signal going to the base of the BJT switch. What changes should I make in order to obtain higher voltage across R1? Any help would be highly appreciated.
EDIT: I simulated the circuit using nmos, managed to get the waveform but the p-p voltage is too low (24mV as opposed to 48V). What might be the reason for this?
