In the Infineon Application Note, two of the parameters they've used to calculate the switching loss of the MOSFET are Vds(on) and Vds(off).
- Is the Vds(off) the blocking voltage?
- Where do they obtain the Vds(on) and Vds(off) values from? Are they:
- arbitrarily chosen
- taken directly from the datasheet
- dependent on the converter it's used in
- If it's the third option, how to calculate the Vds(off) specifically?
Reference:
Application Note: https://www.infineon.com/dgdl/Infineon-ApplicationNote_MOSFET_CoolMOS_How_to_select_the_right_CoolMOS-AN-v01_00-EN.pdf?fileId=db3a304412b407950112b40acf580693
MOSFET Datasheet: https://www.datasheetarchive.com/pdf/download.php?id=76cd77451b2171be9a0ed7cbcf732382c7b37e&type=M&term=SPP04N60C3
