A system I built uses a commodity siren for audio feedback. In production it's outdoors and 50m from the operator and the volume level is just right. On my bench it's deafening. The tone generator board lacks provision for volume adjustment so I suppose I'll have to attenuate the output.
The whole system is nominally 30W. The resistive component of the horn seems to be about 6Ω. Quite likely this is nominally an 8Ω device.
All the pots I have lying about are for much higher resistances; it seems to me I need to add quite a small resistance. Would I be better off trying to adjust bias on one of the the amplifying transistors? How would you go about adding volume control?
I have already taken the amusingly prosaic step of putting a sock in it. When working on other aspects I simply disconnect the horn but for wiring and system integration checks there's no getting away from it.
For those who like to have the background info...
- The module at left is a 30A relay with optoisolator for low trigger current.
- The horn tone generator is the centre module in this photo.
- Immediately above the tone generator is a garage remote relay module that connects an Arduino digital input to GND when the fob button is pressed.
- At right is an Arduino Nano socketed on a screw terminal board.
- The round thing at top is a piezo buzzer providing audio feedback on the bench.
Seen in profile along the bottom wall we have
- A buck converter adjustable step-down module providing 5V for the Arduino
- A buck converter adjustable step-down module providing 6V for the servomotor
- A Freetronics microphone module used to detect engine run state so the controller knows about manual engine start/stop.
Yes it really is all held together by industrial Velcro. What started out as a convenience in a rapidly evolving prototype turned out to be an outstanding shock-mount.
The controller and a big diesel water pump are 100m away down at the river. Due to terrain they are barely audible from outside the house and completely inaudible inside. The neighbour's dogs bark at everything else but the pump doesn't seem to bother them.
