I have downloaded a model of a MOSFET from ON Semiconductor and have a problem with it. The "model" looks like this:
* LTspice Encrypted File
* This encrypted file has been supplied by a 3rd
* party vendor that does not wish to publicize
* the technology used to implement this library.
* Permission is granted to use this file for
* simulations but not to reverse engineer its
* contents.
* On Semiconductor SiCMOSFET 1200V Model Library
* Last Update: Jan. 28, 2020
* Model Version: 1.5
* Simulator: LTspice
* Model Contacts:
* James Victory James.Victory@onsemi.com
* Ken He kencanzhong.he@onsemi.com
* Scott Pearson Scott.Pearson@onsemi.com
* Hyeongwoo Jang Hyeongwoo.Jang@onsemi.com
* Stan Benczkowski Stan.Benczkowski@onsemi.com
* Yunpeng Xiao YunPeng.Xiao@onsemi.com
* Reversion History:
* Vers. Date Brief Description
* 1.0 02/12/2019 Generated models for NTHL080N120SC1, NVHL080N120SC1, and SVHL080N120SC1
* 1.1 08/26/2019 Added models for NVBG020N120SC1.
* 1.2 10/09/2019 Update the base model for largeDie devices to the vers1i.
* 1.3 12/12/2019 1. Added VG dependence to the body diode forward IV in the largeDie device
* base model.
* 2. Added product models for NTBG020N120SC1, NTHL020N120SC1, NVHL020N120SC1
* NVH4L080N120SC1 and NTH4L080N120SC1.
* 1.4 01/10/2020 Added product models for NTHL040N120SC1, NVHL040N120SC1, NTHL160N120SC1, NVHL160N120SC1
* NTH4L160N120SC1 and NVH4L160N120SC1.
* 1.5 01/28/2020 Added product models for NTH4L020N120SC1, NVH4L020N120SC1, NTH4L040N120SC1, NVH4L040N120SC1
* Usage:
* This library contains 3 and 5 pin(or terminal) models. The models include
* self heating effects and were characterized under pulse conditions from
* 10us to 1ms conditions.
* The 5p models contain 2 additional pins tj (or junction temperature) and
* tcase (or device case thermal terminal).
* tj should always be left floating or can be connected to a very
* large resistor (>1meg). This terminal is meant to provide the user with
* output information on the junction temperature under operation. For model
* verification purposes against the data sheet and isothermal device simulations
* for example, tcase should be connected to a voltage source with value {TEMP},
* the simulator ambient temperature. For system/module level simulations that
* include thermal effects, tcase should be connected to the device-module
* thermal interface node such as the heat sink interface point.
* Support devices:
* NTHL080N120SC1_3p, NTHL080N120SC1_5p
* NVHL080N120SC1_3p, NVHL080N120SC1_5p
* SVHL080N120SC1_3p, SVHL080N120SC1_5p
* NVBG020N120SC1_4p, NVBG020N120SC1_6p
* NTBG020N120SC1_4p, NTBG020N120SC1_6p
* NTHL020N120SC1_3p, NTHL020N120SC1_5p
* NVHL020N120SC1_3p, NVHL020N120SC1_5p
* NVH4L080N120SC1_4p, NVH4L080N120SC1_6p
* NTH4L080N120SC1_4p, NTH4L080N120SC1_6p
* NTHL040N120SC1_3p, NTHL040N120SC1_5p
* NVHL040N120SC1_3p, NVHL040N120SC1_5p
* NTHL160N120SC1_3p, NTHL160N120SC1_5p
* NVHL160N120SC1_3p, NVHL160N120SC1_5p
* NTH4L160N120SC1_4p, NTH4L160N120SC1_6p
* NVH4L160N120SC1_4p, NVH4L160N120SC1_6p
* NTH4L020N120SC1_4p, NTH4L020N120SC1_6p
* NVH4L020N120SC1_4p, NVH4L020N120SC1_6p
* NTH4L040N120SC1_4p, NTH4L040N120SC1_6p
* NVH4L040N120SC1_4p, NVH4L040N120SC1_6p
** Begin:
72 90 B0 68 54 0D 9A 07 A9 04 16 53 E8 32 9E 34
1A 71 F7 82 AF 56 34 5A EF 25 6A BD 21 44 17 A4
0D 50 65 6D 98 1C 07 C6 21 7F D1 6A F4 E8 F6 F5
29 F0 DF 44 9F D7 2A 8A
* End 3708261714 511592688
So there is no .SUBCKT commands or something else... I haven't found any tutorials in Internet either. How can I import this model in LTSpice?
Thank you in advance!
