My understanding of how this works is quite poor, I've tried reading many sources but just got even more confused by the terms crystals, crystal resonators, ceramic resonators, oscillators, crystal oscillators.
What I know is that when you have a simple 2 pin crystal you add 2 caps to it so that it resonates properly. And the AVR chip I am connecting it too (Atmega328p) has some other internal circuitry for it to work.
I am looking at using an smd crystal in my design and my question is, for a crystal like this: enter image description here
Do I still need the external capacitors or not? I originally thought I would but looking at the specs of the parts they all have a label "capacitance". Does that imply it has caps inside? Or is that recommended value for my caps? Or is that some other capacitance?
Sorry if this doesn't make sense I am just really confused. Thanks in advance!
Edit to include specifics: I have these crystals https://lcsc.com/product-detail/SMD-Crystal-Resonators_Seiko-Epson-X1E000021011900_C89371.html But it seems they are quite standard so here is one with English datasheet: https://www.mouser.co.uk/ProductDetail/ECS/ECS-160-12-37B-CTN-TR?qs=sGAEpiMZZMukHu%252BjC5l7Yb4vS8HZNl%252BL%2F78jMNI6Q2E%3D
  • I suggest that you study existing "microcontroller with a crystal oscillator" designs and try to find one that does **not** have the two crystal load capacitors. I bet that you will not find any because they are needed. In some cases the oscillator might work without the capacitors but no one counts on that. You're making too much fuss over two small capacitors. – Bimpelrekkie Aug 12 '20 at 12:07
  • I think the confusion might come from the fact that ceramic resonators can include the internal load capacitors and that is why they have a ground pin too. – Justme Aug 12 '20 at 12:10
  • Ye ik they are required in the cercuit somewhere but I've seen people use parts which contain the capacitors inside them so no additional ones required outside. But don't know what its called. – Eugene Levinson Aug 12 '20 at 12:10
These parts are crystals that can be used with typical microcontrollers that have a built-in Pierce oscillator, and thus require the rated external load capacitance in order to oscillate at the rated frequency.
So yes, external capacitors are needed as usual for crystals. The extra two pins are just to ground the metal lid.
And no, the rated load capacitance does not mean the value of the capacitors. It is the total capacitance as seen by the crystal, which includes the capacitors, PCB wire capacitance, MCU IO pin capacitance and other stray capacitances. The ECS part is rated for 12pF load capacitance, so two 24pF capacitors would give it 12pF of load if no other capacitances are considered. But the capacitors must have smaller value due to the other stray capacitances.16pF capacitors would be used to give 8pF load if the stray capacitances are approximated to be 4pF.
Justme
  • 127,425
  • 261
  • Thanks a lot! So the specified capacitance is the recoomended/required value of the capacitors? – Eugene Levinson Aug 12 '20 at 12:08
  • @JustMe What makes you say they are "meant for parallel resonance circuit"? – Andy aka Aug 12 '20 at 12:09
  • @Andyaka because they have a load capacitance rating it means they are for parallel resonant circuit. Crystals meant for series resonance don't have load capacitance rating, as they read "series" in place of the capacitance. Of course the crystal does not know in which circuit it is used, it will still oscillate but it won't run at the rated frequency. – Justme Aug 12 '20 at 12:14
  • When there are load capacitors used, the actual crystal runs close to its series resonance i.e. it's low impedance point. This is how it produces a phase shift of nearly 180 degrees. It can't achieve that when run in it's parallel resonance point. Maybe you are (we are) confusing the terms here? An xtal for a standard MCU oscillator will run close to its series resonant point. – Andy aka Aug 12 '20 at 12:50
  • @Andyaka You are quite right, the crystal is not run at the parallel resonance point. The actual operating point is between series and parallel resonance points, called the "area of usual parallel resonance", often simplified to as just "parallel resonance". In that area, the reactance is positive, so the crystal looks inductive. The oscillator circuits are also simply classified as series or parallel circuit, and the Pierce type which is typical oscillator type within MCUs is a parallel type. The crystal is just manufactured so that it runs at the labeled frequency with the rated capacitance. – Justme Aug 12 '20 at 14:36
  • A crystal based Pierce oscillator runs at very near to the series resonant point. I think you have got things back to front. And, the CMOS implementation of a Pierce oscillator is no different - it is a series resonant circuit primarily. Your answer says "These parts are crystals that are meant for parallel resonance" and that is not true. See [this answer](https://electronics.stackexchange.com/questions/413054/confusing-quartz-crystal-impedance-graphs/413064#413064). – Andy aka Aug 12 '20 at 14:42
  • @Andyaka I don't argue about what you say - and indeed, the crystal seems to be run very close the series resonant point (but in the "area of parallel resonance"). However, this is the terminology that is prevalent in crystal manufacturer appnotes. Pierce oscillator is usually said to be "parallel" (but "series" by Microchip) and the crystals as "parallel resonant". For reference : https://www.ctscorp.com/wp-content/uploads/Appnote-Crystal-Basics.pdf http://ww1.microchip.com/downloads/en/appnotes/00826a.pdf https://www.qvstech.com/wp-content/uploads/2014/08/Crystal-Application-Notes.pdf – Justme Aug 12 '20 at 15:09
  • The CTS document is basically wrong or at best misleading. The use of the term "area of parallel resonance" is not correct. The Microchip document also appears to be incorrect in this area. If an ESR is specified then the crystal is intended to be used in near-series resonance. The datasheet link in the question contains ESR values hence it is near-series resonant. Parallel resonance can't make use of ESR. Capacitance around the xtal to form a pi filter mean that the xtal is near-series resonated and produces a phase shift of circa 170 degrees. This in no way happens at parallel resonance. – Andy aka Aug 12 '20 at 15:56
  • Bloody hell that Microchip document is really contradictory. It's words on the colpitts oscillator is rubbish. Aha I see you have removed references to series and parallel. – Andy aka Aug 12 '20 at 16:02
