I need to measure the noise performance of an DAC + Amplifier combination. The system has a bandwidth of ~100MHz and the expected noise level is approx. 1-2 mV rms. What is the preferred instrument to do this?
I know there is the R&S URE3, which is only 30MHz and discontinued. Is a spectrum analyzer the best choice? If yes which parameters are critical for this application?
Money is not an issue :)
MiB_Coder
  • 111
    If "money is no object" and you're looking at buying something, I'd simply ask the sales department of R&S and Keysight what they can offer. If this is only an exercise then look at these manufacturers websites, there are plenty of SA to choose from. Yes a SA is the most obvious choice. – Bimpelrekkie Aug 11 '20 at 09:03
    What specifically do you mean when you say "noise performance"? Do you mean you want to measure the noise it produces or it's ability to avoid noise problems on power supplies. – Andy aka Aug 11 '20 at 10:41
    All you need is a DSO with external load and AC coupled to 50 Ohm terminator for matched impedance from coax or 150 ohm from twisted pair to get full bandwidth. – Tony Stewart EE75 Aug 11 '20 at 11:53
  • @Andy aka : I mean the noise present at the output. – MiB_Coder Aug 11 '20 at 15:52
0 Answers0
