I've been using a 134.2 KHz (FDX-B, ISO 11784/85) transponder/reader for use with implanted and pendant tags. However, I've been frustrated as to the range. Is anyone aware of a chip/circuit level solution incorporating that or a similar standard (like 13.56 MHz, ISO/IEC 14443, etc) that can be designed to work reliably at a range of up to 12 inches? For the tag, I only need the basic requirement of transmitting a unique identifier and can use a pendant size tag.
As I understand RFID transponders, I should be able to build an RF emitter with a power output capable of powering a suitable tag at that distance, which when sufficiently energized will automatically broadcast its unique code. And then the remaining challenge is just to build a suitable reader. Is it that simple? Anyone have experience in that area?
