-1
I am 3rd year electronics student.
I want to design a speaker from the circuit level.
As this is my first time, I have no clear idea how to start and where to start.
Can anyone please suggest to me how to design the pre-amplifier and the amplifier circuit for a speaker from scratch?
JRE
  • 67,678
  • 179
    Do you have a speaker already you want to connect to, or are you wanting to design the speaker itself? Do you have mechanical engineering background, or just electrical? – Justin Jul 29 '20 at 18:05
  • I want to design the amplifier and the pre amp for the speaker ,not just to connect. – Hari krishna Goli Jul 30 '20 at 04:19
  • A speaker is just a [speaker.](https://en.wikipedia.org/wiki/Loudspeaker) A powered speaker includes an amplifier in the same box as the speaker. – JRE Jul 30 '20 at 11:49
Can anyone please suggest me some thing how to design the Pre-Amplifier and the Amplifier circuit for a speaker from scratch
Start with a specification of what you intend to achieve in terms of performance, power output, distortion level, power supply range, spectrum, input impedance, tone controls, output load impedance requirements, power efficiency etc.. Then, add a block diagram so that each piece of the jigsaw can be designed individually (thus making the job easier to make progress on).
Then research each block using google and put together a circuit. Next is run the circuit using a simulation package and that's when you come back here for answering the problems you may face. If all goes well with that you layout a PCB and solder on the components and fingers-crossed it works but it's likely you'll need to pay another visit back here to debug some things and you might need an oscilloscope to help.
  • @Hari 1st you accept my answer, then you basically ask the same question again and accept virtually the same answer to that then you delete that 2nd question then you unaccept my answer. Not a very good start but, welcome anyway. – Andy aka Jul 30 '20 at 11:32
  • Oh, then you re-accept my answer!! Next step for you is put together a block diagram of what you need and start filling in the gaps of your specification. This is how EEs do it. – Andy aka Jul 30 '20 at 11:33
  • sorry, for what I have down, I thought It has different question and I just post. I lthough the more answers will come if I don't mark my question as answers.so because of that I did like that. I sincerely apolagige for what I have done. – Hari krishna Goli Jul 30 '20 at 11:39
  • Water under the bridge - concentrate on a block diagram and a specification. – Andy aka Jul 30 '20 at 11:48
I have posted complete schematics for moderate_power audio amplifiers, here on stackX. Try searching. "amplifier"
And in the www.diyAudio.com site, search for "simplistic njfet RIAA" for the discussion thread, moderated by "salas", on excellent vinyl preamp for moving_coil phonograph circuits.
About 3 years ago, a diyAudio poster named "Riccardo"? developed a crucial PCB design with two large areas and a rather thin region between them that served to GROUND the RIAA time_constant capacitors. That long thin region is important in preventing ECHO; since the RIAA has a 50Hz pole (3 millisecond time constant), crosstalk at the 1/100,000 (10 PPM, -100dB) may be audible. You want to have the Preamp output current NOT CIRCULATE around the edge of the PCB and slightly modulate the gate_source voltage of the input JFET.
See this answer for some thoughts on this crosstalk.
Why are the advantages of JFET over MOSFET, or why are JFET still used?
Here is thinking on WHY have the Preamp PCB far away from the Power Amplifier PCB/power_supply.
What's the point in a preamp?
This style of thinking ---- minimize currents in the Ground Plane for precision (echo-less) circuits ---- is important for instrumentation and telemetry and any high_bit_count measurements even if your Signal Chain is only a 22bit or 24 bit or 18 bit ADC.
Often these ADCs have a VREF (voltage reference) pin, along with expectation for a CLEAN QUIET externally-generated voltage.
However, if you have TRASH or SPIKES or simply power_supply_currents that flow in your GROUND PLANE, that VREF will not be constant.
That means your 18/20/22/24 bit ADC will have LOTS OF MEASUREMENT ERRORS.
Thus, for success in the audio world, and success in the precision measurement world, you need to think about GROUND CURRENTS.
A square of standard thickness PCB copper foil has resistance of 0.000500 ohms (that is 1/2,000 ohm or 500 microOhms). A ground current of 0.1 amps, flowing through that square of foil, using Ohms Law V = I * R, produces 0.1 amp * 500 microOhms === 50 microVolts error.
In a 2.5volt FullScale system, that is 20 ppm (parts per million) error. Thus your 24_bit ADC now is only good for 16 bits.
Depending on how that 0.1 amp flows in the GROUND PLANE, this 20ppm might affect the Full Scale or the ZERO POINT, or both.
Learn to sketch the current flows. A grid of resistors in SPICE, maybe of size 10 by 20, or 200 tiny squares, is a good initial thinking tool.
analogsystemsrf
  • 33,703
In the 1970's and 1980's, National Semiconductor put out a series of databooks, handbooks, and manuals on all aspects of analog circuit design. Here is a link to one of their best. Every serious audio circuit designer in the world has used this book or knows about it. Some of the parts it uses are obsolete, but the circuit concepts work just as well with newer parts from other companies.
http://bitsavers.trailing-edge.com/components/national/_dataBooks/1976_National_Audio_Handbook.pdf
AnalogKid
  • 16,865
