I know that phasors are great to solve circuits driven by sinusodial input signals but I was wondering if I can incorporate phasor concepts(like impedance) to circuits driven by input signals not necessarily sinusoids and get an intuition for what is going on at certain nodes. Guessing what a capacitor acts like is very difficult to me so I try to make my life easier with some tricks like this but I am not sure if it helps any. Does it work in any way?
Can you give a more specific example. Laplace transforms of the circuit multiplied by the laplace of the input signal might help. – Andy aka Jul 25 '20 at 08:03
related: https://electronics.stackexchange.com/questions/358336/is-the-formula-for-inductive-reactance-the-same-when-considering-rectified-ac/ – Sredni Vashtar Jul 28 '20 at 09:11
If the input signals are not sinusoids, and are not periodic signals that can be decomposed into sinusoids, then you will probably need to do some kind of transient analysis or fall back to differential equations.
The impedance value of a capacitor is only valid at a single specific frequency. Without sinusoids the conventional notion of impedance is not very useful.
- 31,192
- 5
- 29
- 67
I mean I see a lot of capacitors in many circuits and I do not quite understand what they do or how they affect voltages across them. Can you give me sone insight – EEguy Jul 25 '20 at 00:52
@EEstudent Math equations are just models of the physical world. Sometimes they work for all cases, sometimes not. Sometimes it's easier to model the same physical system in different ways depending on the goal. That's why you can use differential equations, 's' notation, Smith charts and S-parameters, etc. – Aaron Jul 25 '20 at 01:59
@EEstudent Capacitors are used for several slightly different purposes, at some typical positions in a schematic. If you care to give us an example schematic, someone may comment on the individual capacitors, referring you to further reading on the principal circuit blocks. – frr Jul 28 '20 at 15:39
Capacitors always store charge, perhaps for just a few hundred picoseconds during the half-cycle of a WIFI Radio wave in a channel filter, or for 0.1 second or longer in your power supply that can sustain the computer operation during changeover from line_power to battery_backup_power after line voltage collapses. Or, in past decades to hold the requested vehicle_speed in a automobile cruise control, the capacitor holds the GRID VOLTAGE on a vacuum tube or MOSFET, for an hour or so.
Energy in a capacitor can be computed from the charge.
And the current can be computed, from how the charge is changing.
With current, and voltage, we can compute Impedance. Which we use in single-tone circuit behavior prediction.
However, if we map the Impedance, or compute the Impedance over a range of frequencies, we can use Fourier Methods and/or Convolution Method, to predict results of Complicated (real world) waveforms and signals and data sequences and modulations.
- 33,703
- 2
- 18
- 46
What is Phasor exactly? If you take an electric circuit, and think of it as a linear system, then the output phasor is the Fourier transform of the network function multiplied by the Fourier transform of your sinus input. As I understand you wish to analysis the circuit not only for sin and cos input. For that, what I would do is analysis the circuit using the Laplace transform.For instant, you want to understand the behavior of RC circuit. Try writing the circuit eq. Apply the Laplace transform of both sides. You can understand a lot by analysing what you get using the Laplace transform properties.
- 78
- 5
analogsystemsrf has already hinted at my cheeky answer: if you need to work with non-sinuoidal signals, rather than a nice sinewave specified by a single frequency, the response of your circuit will be a spectrum, rather than a single "phasor" :-) A spectrum of phasors across some frequency range of your interest... This is because your input signal is a spectrum as well. Fourier Transform works for any signal. The dubious fun begins, where you introduce non-linearity into the circuit. Especially dubious and pointles, if your circuit is some basic digital system, rather than a principally analog signal chain. But if you're actually speaking about analog signal processing by DSP methods, that's a whole different story...
You've mentioned capacitors. If you apply an RC filter to a rectangular waveform, there are two basic cases: you get a low-pass or high-pass filter response. Which means that you suppress the higher harmonics, or suppress the "fundamental"... The link above points to a tutorial site with some static explanation of the maths. If you want something "live" to play with, I suggest that you try modeling stuff in Qucs or QucsStudio.
- 2,573
- 12
- 14
