I bought a DIY crane machine online and I'm trying to work out how to set up the power supply.
The power supply they provided in the photos looks setup like this, where elements are screwed into the power supply:
https://gyazo.com/b30a3d192a799a9513d32b92e5e4fd9a
In this example above, some of the connections are for the rocker switch & plug. But at the moment, I'm mainly interested in connecting the cables which come from the motherboard in the correct way. The cables that need to be connected to the power supply look like this:
https://gyazo.com/82856b58e3b1f74935cde8b067ac64e3 (The cables in the motherboard)
https://gyazo.com/694600f6beca6003b89fae9a3b11a7ca (The other end of the cables)
The main problem is that the power supply sent to me doesn't have screws like in their example, it just has header pins. This is what the power supply looks like:
https://gyazo.com/29abae5454328bed9581bb0c4f246f75
On the left pins, there is a Molex Housing which fits into this section, but the pins sticking out for the motherboard connections don't make sense to me. I tried buying a 6 way single rail Molex housing with 3.96 mm pitch, but it just doesn't fit and I can't find any suitable female connectors that would seemingly fit this.
So my question to anyone that can help me is: what do I need to get this connected properly and where should the cables go?
Following this, I would also like some advice on attaching the rocker switch, but one thing at a time :D
Thanks a lot for reading if you've made it this far. Any help would be appreciated.
