I'm hoping to resolve an argument here. Someone else said that lightswitch dimmers don't actually cut back on power used, since they're just resistors and just divert the power to additional heat. I agree that dimmers are just resistors, but from my thinking, V=IR and P=IV gives us P=V^2/R. Voltage is constant in this system, so as resistance increases between the dimmer and the lightbulb in series, power will go down. Who is correct?
3Many dimmers are synchronized with the AC mains power and adjust the phase angle during which they trigger operation. For example, at 50% setting they may trigger half-way through the AC half-cycle. The light would only dissipate for half the time. Since they use semiconductor switches, they don't dissipate much power themselves. Sure, there's a resistor involved. But it is only part of an RC timing circuit and not directly in-line with the load. There are types that only start after a delay from the zero-cross and others that cut things off after a delay. But the basic ideas are similar. – jonk Jul 23 '20 at 02:43
7ac light dimmers are not `just resistors` ... the "someone" does not know what they are talking about – jsotola Jul 23 '20 at 03:00
Does this answer your question? https://electronics.stackexchange.com/questions/38031/building-ac-dimmer-digitally-controlled – vu2nan Jul 23 '20 at 03:20
3_"since [dimmers] are just resistors and just divert the power to additional heat"_ - If that were true, wouldn't dimmers get incredibly hot, especially when dimming bigger incandescent bulbs? – marcelm Jul 23 '20 at 06:59
Even if dimmers were just resistors (they aren't, as explained in the comments), it should be obvious that as the resistance goes up, the current goes down and the lamp gets dimmer. By definition, since power = voltage × current and voltage is being held constant, then the power being consumed scales directly with the current.
Some of the power gets dissipated in the resistor, some of it gets dissipated in the lamp, but the total still adds up to less than the lamp uses at full brightness.
- 168,369
- 17
- 228
- 393
I was wondering what the actual power dissipated in the series resistor compares with the bulb power over a wide dimming range and particularly how much effect there is from the variable filament resistance due to temperature. I tested a 120 volt, 60 watt bulb and also calculated the power assuming no change in filament resistance. The results are shown below.
Wba and Wra are the actual bulb and resistor power plots from the test results. Wbc and Wrc are calculated assuming resistance remains at the hot value during dimming. Wttl is the total bulb plus resistor power.
The bulb was labeled 60 watts, but it only took about 55 watts at about 120 volts. Room temperature was about 72F.
