I am debugging a simple line of code:
float temp_f;
temp_f= temperature[0] +(temperature[1] >> 5)*0.125;
that is assembled into
316: temp_f= temperature[0] +(temperature[1] >> 5)*0.125;
0x080018CE 4C1C LDR r4,[pc,#112] ; @0x08001940
0x080018D0 7860 LDRB r0,[r4,#0x01]
0x080018D2 0940 LSRS r0,r0,#5
0x080018D4 F7FEFDD6 BL.W __aeabi_ui2d (0x08000484)
0x080018D8 ED9F1B1A VLDR d1,[pc,#0x68]
0x080018DC EC532B11 VMOV r2,r3,d1
0x080018E0 F7FEFD5E BL.W __aeabi_dmul (0x080003A0)
0x080018E4 EC410B18 VMOV d8,r0,r1
0x080018E8 7820 LDRB r0,[r4,#0x00]
0x080018EA F7FEFDCB BL.W __aeabi_ui2d (0x08000484)
0x080018EE EC532B18 VMOV r2,r3,d8
0x080018F2 F7FEFCAE BL.W __aeabi_dadd (0x08000252)
0x080018F6 F7FEFDE5 BL.W __aeabi_d2f (0x080004C4)
0x080018FA 4621 MOV r1,r4
Since the ARM Cortex-M4 FPU is specifically for single precision floating point operations, I cannot understand why the compilation process links everything to double precision instructions like __aeabi_dadd (from what I understand being an external run-time ABI for ARM that runs in software) and only then converting back to float, instead of doing everything directly in single precision floating point format, maybe even in hardware?
This operation is performed inside a timer interrupt routine but I don't have anything related to float in my main process.
I'm using HAL, with cubeMX and Keil.
EDIT: solved by suggestion of @nanofarad writing 0.125f
instead of 0.125
Apparently the default x.y
notation in C is for double values.
