I'm thinking about using a capacitive touch screen (the touch layer only, no display) to detect the position of two moving parts. Each part would have its 'stylus' just above the screen to mark the position. Unfortunately, such a use-case would require a rather large (1.5cm hole in 7cm screen) hole in the middle of the touch screen.
Have you tried to drill a hole into a capacitive touch screen? Will it work afterwards?
Josef Kufner
  • 113
Most of capacitive touch screens are constructed as X,Y array of capacitive sensors.
Once You drill the hole in the middle You will open circuit some connection and might loose possibility to properly sense the touch in the rest of the touch screen. See example below:
It would be better to design custom capacitive Sensing board, that has connection the other way around.
KJA
  • 973
