This example circuit is given in Texas Instrument's application note SLVA001: "Designing Switching Voltage Regulators With the TL494":
Figure 35 from the application note, example circuit.
They use a 140 μH inductor and a 220 μF electrolytic capacitor for the LC filter (capacitor value not printed on the circuit diagram but given in the accompanying calculations). This results in a cutoff frequency around 1 kHz and a -180 degree phase shift in the output. This output is then fed back trough resistive divider R8/R9 to one of the TL494's error amplifiers.
I don't understand why there is no need for any frequency compensation in this example. In fact, both this application note and TI's TL494 datasheet never even mention the error amplifier's phase. In the region above 1 kHz where the LC isn't yet attenuating much and the TL494's error amplifier can still easily reach the configured 40 dB gain surely the loop gain is above unity and the phase shift (LC filter + error amp's own) exceeds -180 degrees?
(I do realize the output capacitor's ESR introduces a zero that makes the LC filter's phase come back to -90 degrees at higher frequencies but that does not seem to be much help in the region right above the LC's cutoff point).
winny
  • 13,064
  • 63
Unimportant
  • 4,335
Having just read about the TL494 in the last 30 minutes or so, I have to conclude that it certainly \$\color{red}{\text{DOES}}\$ need frequency compensation and that back in the day when it came out, people must have realized that and naturally "slugged" the output from pin 3 with a capacitor to either ground or back to pin 2.
It's a poor data sheet and only mentions the word "compensation" three times in two paragraphs (12.1.3 and 12.1.4) but, it cannot work without compensation for the reasons you eloquently stated in your question.
SLVA001 only mentions the "compensation" word once in an unconnected way. If i were you I'd be so appalled at the lack of information that I wouldn't use it. However, along the route to answering the question I came across the AZ7500B and it looks to be identical. They also don't mention much about compensation but they do provide a diagram with a compensation capacitor across pins 2 and 3: -
The above 100 nF capacitor and 1 MΩ feedback resistor have a 3 dB point of 1.6 Hz i.e. it is \$\color{red}{\text{VERY}}\$ slugged in its frequency response and will almost certainly be stable with a vast array of different inductors and output capacitors.
This is a really old app note from TI, and I believe they just lowered the loop gain until it was stable, by killing the error amp gain:
"To increase the stability of the error-amplifier circuit, the output of the error amplifier is fed back to the inverting input through RT , reducing the gain to 101."
So the loop response is probably terrible, and reliant as you said on some phase boost from the ESR zero. I'd be surprised if it didn't ring at the LC frequency when hit by transients. I think the author didn't want to deal with loop compensation in the app note, just the basic function of the part.
Ordinarily you would design a type III compensation network for use with this part, as it's typically a voltage mode loop. There's no magic that lets you get away without a compensator with this part.
John D
  • 22,677
  • 39
  • 56
  • The trouble with that app note and the circuit it refers to (just above those words you quoted), doesn't have a resistor called \$R_T\$ in the error amplifier circuit AND the gain of 101 doesn't tally with the 51 kohm resistor they indicate. This isn't a crit of you; it's a total crit of the poor documentation for this device. – Andy aka Jul 19 '20 at 19:33
  • @Andyaka Yes, pretty dismal isn't it? – John D Jul 19 '20 at 23:37
    The 2005 version of the Application note correctly refers to R7. It looks like either a typo or OCR error in changing the reference from R7 to RT. See https://www.datasheetarchive.com/pdf/download.php?id=af5fd0576577bd343f49a52260e8f8aaf826ef&type=P&term=TL494%2520EQUIVALENT%2520CIRCUIT – elchambro Jul 20 '20 at 00:18
  • @JohnD Indeed, this whole thing came about while studying type III compensators. Thanks. – Unimportant Jul 20 '20 at 13:02
  • The gain of the circuit with R7 of 51K ohms is not 101. With the values indicated, the output error voltage Ve of the amplifier satisfies Ve-2.5 = (Vo-5)*53/6. That is the error is amplified by a factor 53/6 or about 9. The discrepancy comes due to the voltage divider of the REF signal 5V will add to the 510 Ohm resistance of the negative input of the error amplifier. – user1958943 May 02 '22 at 15:07
