I'm working on building an Ardunio Nano device that detects if automotive 12V circuits are on / off. I was able to successfully build & test a sample circuit provided Phil Frost.
The question I have is around saving space. I'm using this in a motorcycle so space is at a premium. The 4N25 uses 6-pins, even though I only use 4. I'm monitoring 6 separate 12V circuits and I'm wondering how to make it more compact.
Is there another chip (maybe a multi-optocoupler) or approach that will help me save PCB real estate?
JRE
  • 67,678
  • 179
Josh
Yes, there are quad optoisolators (one 16-pin package, either surface-mount (0.1" or 0.05" pitch) or old-fashioned DIP).
Just go to your favorite parametric search engine, such as Digikey's and select 4 channel optoisolator.
Product Index>Isolators>Optoisolators - Transistor, Photovoltaic Output
Around 150 choices with different packages, CTRs, voltage ratings etc.
Spehro Pefhany
  • 376,485
  • 842
