I have just bought the following 5-pin switches of eBay: here 5-pin switch
Problem is that no spec came with it and I am now wondered if I can directly wire the LED pins to the main or if I need to add extra electronics.
The LED voltage is part of the ordering options, so if you selected 220VAC, and they got the order right, that should be the correct voltage.
Spehro Pefhany
  • 376,485
  • 842
The seller provided the wiring diagram. I am adding it as an answer as I believe it may help other people to understand how these swtches work. enter image description here enter image description here
