I have a 12V fail-safe electrical strike currently installed and working on a door, but I want it to open slightly when it is powered down, but a spring apparently won't do as my strikes keep themself locked if they have a constant force acting on them (so after unlocking, you either have to pull the door and the spring pushes it away, or push the door in place and the spring pushes it on you)
The question is: is there a way to open slightly the door with another type of electrical strike or is this kind of security on every one of them ? I need it to stay fail-safe though.
The other options I see are a solenoid pushing the door after the strike is opened, or a magnetic lock with a spring. Are there easier workarounds I didn't thought of ?
