Does some one know what standard can be use for quality inspection on a PCBA that have stranded wires soldered and fixed with RTV?
I check the IPC-A-610 Rev E and the most similar criteria, is in the section 7.2.2, but it is for Axial/Radial components.
This is the comment from the IPC standard:
On an unsleeved vertically mounted component there are a minimum of 2 beads of staking material for at least 25% of its length (L), and 25% of its circumference. Adhesion to the mounting surface is evident.
I might be able to adapt the criteria to stranded wires, but I am working in a medical industry and a standard is preferred, otherwise I'll have to validate it.
Thanks in advance for your support.
