I'm getting a Time step too small
error in LTspice. It says it's having trouble with node "e:u2:_e27#branch"
. I assume that'd be somewhere around the U2 component, but hovering over all of its pins only shows N*** in the bottom-left corner. I'd like to know where exactly this node is so I can add some resistance/capacitance to help the simulation.
Netlist:
V1 0 N017 325 Rser=1m
V2 N001 0 325 Rser=1m
XU2 0 N013 0 N007 N010 N008 N016 N002 N002 N004 N014 highS1 lowS1 NC_01 NC_02 NC_03 UCC21520_TRANS
C2 N002 0 100nF
V4 N002 0 5 Rser=0.1
R4 N007 SPWM+ 51
R5 N010 SPWM- 51
C3 N007 0 33pF
C4 N010 0 33pF
R6 N013 0 25k
C5 N013 0 2.2nF
XU4 N006 lowG1 lowS1 N017 N015 NC_04 C3M0075120K
XU5 N001 highG1 highS1 N006 N003 NC_05 C3M0075120K
V§iso1 N004 highS1 15 Rser=0.1
V§iso2 N014 lowS1 15 Rser=0.1
R7 lowG1 N016 2.2
R8 P001 N016 0.1
D1 lowG1 P001 1N5819
R9 lowG1 lowS1 10k
C6 N014 lowS1 1µF
R10 highG1 N008 2.2
R11 P002 N008 0.1
D2 highG1 P002 1N5819
R12 highG1 highS1 10k
C7 N004 highS1 1µF
V8 N003 0 25
V9 N015 0 25
R1 0 N006 8
C1 N001 N006 1n Rser=100
C8 N006 N017 1n Rser=100
V3 N012 0 SINE(0 5 50 0 0 180) Rser=0.1
V5 N009 0 PWL REPEAT FOREVER (0 5.01 19.9999u 0 20u 5.01) ENDREPEAT Rser=0.1
V6 N011 0 5 Rser=0.1
XU1 N012 N009 N011 0 SPWM- LTC6752
V7 N005 0 SINE(0 5 50 0 0 0) Rser=0.1
XU3 N005 N009 N011 0 SPWM+ LTC6752
R2 SPWM- 0 1k
R3 SPWM+ 0 1k
.model D D
.lib C:\Users\Cedric\Documents\LTspiceXVII\lib\cmp\standard.dio
.tran 20ms
* Isolated gate driver
.options abstol=1e-10
.options reltol=0.003
* SPWM Generation
.lib "C:\Users\Cedric\Documents\LTspiceXVII\lib\sym\Imported\Wolfspeed MOSFETs\C3M0075120K.lib"
.lib C:\Users\Cedric\Documents\LTspiceXVII\lib\sym\Imported\UCC21520\UCC21520_TRANS.lib
.lib LTC7.lib
.backanno
.end
UCC21520_TRANS.lib:
.SUBCKT UCC21520_TRANS DISABLE DT GND INA INB OUTA OUTB VCCI_0 VCCI_1 VDDA VDDB
+ VSSA VSSB NC_0 NC_1 NC_2
R_VCCI VCCI_0 VCCI_1 1m
R_R4 0 INA_OK 1K TC=0,0
E_ABM6 DRVB 0 VALUE { IF(V(N16672594) > 2.5, V(N16673112), 0) }
R_R36 N16671640 N16671702 1 TC=0,0
E_E27 INB_OKD 0 INB_OK 0 1
C_C38 0 N17110019 2n
R_R45 N16672776 VDDB 0.5 TC=0,0
R_R40 INB_OKD N17396123 2 TC=0,0
E_ABM4 UVLO2 0 VALUE { if ( V(N16670780) > V(N16668898), 5 , 0 ) }
E_E28 INA_OKD 0 INA_OK 0 1
E_E9 N17051757 0 VALUE { if ( V(DRVB, 0) <2.45, 5, 0 ) }
G_ABM2I2 N16671580 N16671552 VALUE { IF(V(INA_OKD) < 2.5 ,
+ If(V(DEAD_THRESH)< 5u, 0.35, LIMIT((V(DEAD_THRESH)*100/V(VCCI_INT)), 0.35,0)),
+ 0) }
T_T1 INA_PRE 0 INA_OK 0 Z0=1K TD=14n
X_U60 N17110019 N17110021 d_d1 PARAMS:
R_R35 INB_OKD N16670162 3.5 TC=0,0
R_R1 UVLO1 UVLO1_DELAYED 36k TC=0,0
C_C35 0 N17396123 1.443n
R_R43 GND DT 1G TC=0,0
E_ABM31 N16669068 0 VALUE { IF( (V(NO_DT)>2.5 |
+ +V(DRVA_PASS) >2.5) &
+ +V(N16670790) >2.5, 5, 0) }
R_R46 UVLO1 N168057010 770 TC=0,0
X_S4 N17153666 0 N17127259 VSSA UCC21520_TRANS_S4
R_R44 N17051757 N17051744 3.3 TC=0,0
E_ABM21 INB_PRE 0 VALUE { IF(V(N16673790) > 0.51 , 5 , 0) }
C_C32 0 N16671702 1n
E_ABM5 DRVA 0 VALUE { IF(V(N16669068) > 2.5, V(N16669580), 0) }
C_C29 0 N16671468 1n
C_C23 0 N16671236 1.443N
X_U47 INB_OKD N17396123 d_d1 PARAMS:
E_E12 N16673492 N16673432 N16671166 0 {-0.8/5}
E_E15 N17110038 VSSA N17110019 0 1
X_U56 UVLO2_DELAYED N168247370 d_d1 PARAMS:
C_C1 0 UVLO1_DELAYED 1.443n TC=0,0
X_U55 UVLO1_DELAYED N168057010 d_d1 PARAMS:
E_E3 N16669308 OUTA VALUE { if ( V(DRVA, 0) >2.5, 12, 0 ) }
E_E5 N16668898 N16668890 N17196585 0 {-0.5/5}
C_C37 0 N17051744 2n
X_U62 DRVB N17167706 INV_BASIC_GEN PARAMS: VDD=5 VSS=0 VTHRESH=2.5
R_R47 UVLO2 N168247370 340 TC=0,0
R_R42 N16670816 VCCI_0 1 TC=0,0
R_R53 N17196585 UVLO2 1 TC=0,0
R_R3 GND INA 50k TC=0,0
R_R30 N16669868 N16672528 5 TC=0,0
X_U38 INB_OKD N16670162 d_d1 PARAMS:
E_ABM3 N16673116 0 VALUE { if ( V(INB_INT) > V(N16673418), 1, 0 ) }
X_U59 N17051744 N17051757 d_d1 PARAMS:
R_R50 N17088411 OUTA 0.135 TC=0,0
E_E23 N16671044 0 VDDB VSSB 1
X_M15 N16672968 N17051771 VSSB lowmos PARAMS:
X_U39 INA_OKD N16671830 d_d1 PARAMS:
E_E1 N16669842 N16669834 N17201974 0 {-0.2/5}
R_R2 UVLO2 UVLO2_DELAYED 50k TC=0,0
R_R48 UVLO2B N168409120 340 TC=0,0
X_S2 N16671850 0 N16671552 0 UCC21520_TRANS_S2
X_U35 OUTB VDDB d_d1 PARAMS:
E_E25 N16673358 0 DISABLE GND 1
E_ABM24 N16670228 0 VALUE { IF( V(N16670120) > V(N16670672) , 5 , 0 )
V_V3 N16668890 0 8.5
X_M12 N16970878 N16669308 OUTA highmos PARAMS:
C_C28 0 N16670120 1n IC=0
C_C2 0 UVLO2_DELAYED 1.443n TC=0,0
X_U57 UVLO2B_DELAYED N168409120 d_d1 PARAMS:
E_ABM29 N16671850 0 VALUE { IF( V(INA_OKD)<2.5 &
+ +V(N16671830) >2.5, 5, 0 ) }
E_E14 N17051771 VSSB N17051744 0 1
E_E19 INA_INT 0 INA GND 1
V_V1 N16669834 0 2.7
C_C40 VSSB N17167704 110p
C_C33 0 N16671552 1n IC=0
T_T3 N16671236 0 N16669674 0 Z0=1K TD=19n
R_R51 N16672968 OUTB 0.135 TC=0,0
R_R55 N17201974 UVLO1 1 TC=0,0
V_V4 N16673354 0 1.8
R_R6 UVLO2B UVLO2B_DELAYED 50k TC=0,0
X_U42 UVLO2_DELAYED FAULT_INP N16670790 AND2_BASIC_GEN PARAMS: VDD=5
+ VSS=0 VTHRESH=2.5
E_E21 VCCI_INT 0 VCCI_0 GND 1
E_E2 N16672306 N16672276 N16669868 0 {-0.8}
C_C43 0 N17201974 1n
E_E24 DIS 0 N16669674 0 1
X_U40 N16671552 N16671580 d_d1 PARAMS:
X_S1 N16670408 0 N16670120 0 UCC21520_TRANS_S1
C_C3 0 UVLO2B_DELAYED 1.443n TC=0,0
X_U44 UVLO1_DELAYED N16698404 FAULT_INP AND2_BASIC_GEN PARAMS: VDD=5
+ VSS=0 VTHRESH=2.5
E_ABM8 N16671166 0 VALUE { if ( V(N16673358) > V(N16673492), 5 , 0 )
I_IQuiescentA VDDA VSSA DC 1.2m
X_S3 DRVA 0 VDDA N17127259 UCC21520_TRANS_S3
E_ABM2 N16669868 0 VALUE { if ( V(INA_INT) > V(N16672306), 1 , 0 ) }
X_U37 N16670120 N16670154 d_d1 PARAMS:
R_R56 INA_OKD N17407797 2 TC=0,0
E_E4 N17110021 0 VALUE { if ( V(DRVA, 0) <2.45, 5, 0 ) }
E_E8 N16673112 0 INB_OK 0 1
I_Iq_vcc VCCI_0 GND DC 2m
E_E22 N16670780 0 VDDA VSSA 1
E_ABM7 UVLO2B 0 VALUE { if ( V(N16671044) > V(N16670896), 5 , 0 ) }
E_ABM32 N16672594 0 VALUE { IF( (V(NO_DT)>2.5 |
+ +V(DRVB_PASS) >2.5) &
+ +V(N16669858) >2.5, 5, 0) }
X_S5 DRVB 0 VDDB N17167704 UCC21520_TRANS_S5
X_M13 N17088411 N17110038 VSSA lowmos PARAMS:
E_ABM20 INA_PRE 0 VALUE { IF(V(N16672528) > 0.51 , 5 , 0) }
E_ABM25 NO_DT 0 VALUE { IF(V(DEAD_THRESH) <1n, 5,0) }
X_U48 INA_OKD N17407797 d_d1 PARAMS:
V_V2 N16672276 0 1.8
R_R49 N16970878 VDDA 0.5 TC=0,0
E_ABM23 N16671640 0 VALUE { IF( V(N16671552) > V(N16672106) , 5 , 0 )
R_R10 GND INB 50k TC=0,0
V_V10 N16670888 0 8.5
C_C44 0 N17407797 1.443n
X_S6 N17167706 0 N17167704 VSSB UCC21520_TRANS_S6
R_R5 0 INB_OK 1K TC=0,0
X_U43 UVLO2B_DELAYED FAULT_INP N16669858 AND2_BASIC_GEN PARAMS: VDD=5
+ VSS=0 VTHRESH=2.5
V_V7 N16673432 0 1.8
E_ABM27 DRVA_PASS 0 VALUE { IF( V(N16671468)>2.5 &
+ +V(N17396123) < 2.5, 5, 0) }
R_R28 DISABLE GND 100k TC=0,0
V_V9 N16672106 0 1
V_V5 N16670154 0 2
X_U33 OUTA VDDA d_d1 PARAMS:
R_R54 N17198437 UVLO2B 1 TC=0,0
C_C39 VSSA N17127259 110p
C_C42 0 N17198437 1n
E_E20 INB_INT 0 INB GND 1
T_T2 INB_PRE 0 INB_OK 0 Z0=1K TD=14n
I_IQuiescentB VDDB VSSB DC 1.2m
E_E6 N16672784 OUTB VALUE { if ( V(DRVB, 0) >2.5, 12 , 0 ) }
V_V8 N16671580 0 2
R_R29 N16671166 N16671236 1 TC=0,0
C_C24 0 N16672528 1.443n
X_U54 DIS N16698404 INV_BASIC_GEN PARAMS: VDD=5 VSS=0 VTHRESH=2.5
V_V6 N16670672 0 1
E_E11 N16670896 N16670888 N17198437 0 {-0.5/5}
E_E7 N16669580 0 INA_OK 0 1
X_U61 DRVA N17153666 INV_BASIC_GEN PARAMS: VDD=5 VSS=0 VTHRESH=2.5
C_C31 0 N16671830 1.443n
E_ABM1 UVLO1 0 VALUE { if ( V(VCCI_INT) > V(N16669842), 5 , 0 ) }
R_R33 N16673116 N16673790 5 TC=0,0
C_C30 0 N16670162 1.443n
E_ABM28 DRVB_PASS 0 VALUE { IF( V(N16671702)>2.5 &
+ +V(N17407797) < 2.5, 5, 0) }
R_R38 0 N16669674 1k TC=0,0
C_C27 0 N16673790 1.443N
X_H1 N16670816 DT DEAD_THRESH 0 UCC21520_TRANS_H1
X_M14 N16672776 N16672784 OUTB highmos PARAMS:
E_ABM26 N16670408 0 VALUE { IF( V(INB_OKD)<2.5 &
+ +V(N16670162) >2.5, 5, 0 ) }
C_C41 0 N17196585 1n
R_R52 N17110021 N17110019 3.3 TC=0,0
E_E10 N16673418 N16673354 N16673116 0 {-0.8}
R_R37 INA_OKD N16671830 3.5 TC=0,0
G_ABM2I1 N16670154 N16670120 VALUE { IF(V(INB_OKD) < 2.5 ,
+ 0) }
R_R34 N16670228 N16671468 1 TC=0,0
.ENDS UCC21520_TRANS
.subckt UCC21520_TRANS_S4 1 2 3 4
S_S4 3 4 1 2 _S4
RS_S4 1 2 1G
.MODEL _S4 VSWITCH Roff=1e6 Ron=5m Voff=0.5V Von=4.5V
.ends UCC21520_TRANS_S4
.subckt UCC21520_TRANS_S2 1 2 3 4
S_S2 3 4 1 2 _S2
RS_S2 1 2 1G
.MODEL _S2 VSWITCH Roff=1e9 Ron=10m Voff=1 Von=4
.ends UCC21520_TRANS_S2
.subckt UCC21520_TRANS_S1 1 2 3 4
S_S1 3 4 1 2 _S1
RS_S1 1 2 1G
.MODEL _S1 VSWITCH Roff=1e9 Ron=10m Voff=1 Von=4
.ends UCC21520_TRANS_S1
.subckt UCC21520_TRANS_S3 1 2 3 4
S_S3 3 4 1 2 _S3
RS_S3 1 2 1G
.MODEL _S3 VSWITCH Roff=1e6 Ron=25 Voff=0.5V Von=4.5V
.ends UCC21520_TRANS_S3
.subckt UCC21520_TRANS_S5 1 2 3 4
S_S5 3 4 1 2 _S5
RS_S5 1 2 1G
.MODEL _S5 VSWITCH Roff=1e6 Ron=25 Voff=0.5V Von=4.5V
.ends UCC21520_TRANS_S5
.subckt UCC21520_TRANS_S6 1 2 3 4
S_S6 3 4 1 2 _S6
RS_S6 1 2 1G
.MODEL _S6 VSWITCH Roff=1e6 Ron=5m Voff=0.5V Von=4.5V
.ends UCC21520_TRANS_S6
.subckt UCC21520_TRANS_H1 1 2 3 4
H_H1 3 4 VH_H1 1
VH_H1 1 2 0V
.ends UCC21520_TRANS_H1
.subckt d_d1 1 2
d1 1 2 dd
.model dd d
+ n=0.001
.ends d_d1
.subckt lowmos d g s
m1 d g s s _mod
.model _mod nmos
+ kp=2e-009
+ w=2.4
+ l=1e-008
+ vto=0
+ n=2.5
+ rg=0
+ cgso=0
.ends lowmos
.subckt highmos d g s
m1 d g s s _mod
.model _mod nmos
+ kp=2e-009
+ w=0.285
+ l=1e-008
+ vto=0
+ n=2.5
.ends highmos
.SUBCKT AND2_BASIC_GEN A B Y PARAMS: VDD=1 VSS=0 VTHRESH=0.5
E_ABMGATE YINT 0 VALUE {{IF(V(A) > {VTHRESH} &
+ V(B) > {VTHRESH},{VDD},{VSS})}}
RINT YINT Y 1
CINT Y 0 1n
.ENDS AND2_BASIC_GEN
.SUBCKT OR2_BASIC_GEN A B Y PARAMS: VDD=1 VSS=0 VTHRESH=0.5
E_ABMGATE YINT 0 VALUE {{IF(V(A) > {VTHRESH} |
RINT YINT Y 1
CINT Y 0 1n
.ENDS OR2_BASIC_GEN
.SUBCKT INV_BASIC_GEN A Y PARAMS: VDD=1 VSS=0 VTHRESH=0.5
E_ABMGATE YINT 0 VALUE {{IF(V(A) > {VTHRESH} ,
+ {VSS},{VDD})}}
RINT YINT Y 1
CINT Y 0 1n
.ENDS INV_BASIC_GEN
