I have a car radiator fan which when measured with a multimeter on a 12 V car battery draws 4.7 A. I've been trying to run it off an old PC SMPS which is rated at 450 W with a max. current of 18 A at 12 V.
The SMPS doesn't start when I connect the fan to the power supply while the SMPS fan starts running when there is no load. What would be the problem? Can adding a capacitor make the radiator fan start working? If yes, what values should the capacitors be? What is the right solution to get it working?
