I am working on a secondary bootloader for a Renesas microcontroller.
Following are two consecutive records of the 11000+ records in the HEX file.
:04D1D000000000005B
:10D1DC0001030600001000000080000000000100A8
Decoding this the simpler :LLAAAATT
way:
:04D1D000000000005B
means:
- Length of data: 0x04 bytes
- Address to put data at:
0xD1D0
+ Base address set previously, in this case it was0xA0000
- Record type: 00 Meaning, its a Data record.
- Data:
00000000
which is0x00
,0x00
,0x00
and0x00
when represented as bytes. - Checksum of the record:
0x5B
means:
- Length of data: 0x10 bytes
0xD1DC
- Data:
which is data that should be programmed from location0xAD1DC
0xA8
If we look at the addresses, we know what data is to be programmed from 0xAD1D0
to 0xAD1D3
which is 4 bytes. And we know, what data is to be programmed from 0xAD1DC
to 0xAD1EC
which is 16 bytes.
What should the memory between 0xAD1D4
to 0xAD1DB
(both inclusive) which is 8 bytes be filled with? Is it 0xFF
or 0x00
I checked that these locations have no special significance and are not reserved locations as such.
