i learn something formula of Bridge and full wave rectifier from my book
  1. DC voltage \$V_{DC}=V_m-\frac{V_{r_{(pp)}}}{2}\$,\$V_m\$ is the amplitude of sine wave voltage, \$V_{r_{(pp)}}\$ is the peak to peak voltage of ripple wave
  2. The RMS voltage value of ripple \$V_{r_{(rms)}}=\frac{V_{r_{(pp)}}}{2\sqrt{3}}\$
  3. If \$f=60Hz,V_{r_{(rms)}}=\frac{2.4V_{DC}}{R_L C}\$
  4. Ripple factor \$ =\frac{2.4}{R_L C} \times 100 \% \$
i have some questions about the formula above
Q1
In the 2. formula,how is the \$2\sqrt{3}\$ calculated?i mean,based on what reason,so we can say \$V_{r_{(rms)}}=\frac{V_{r_{(pp)}}}{2\sqrt{3}}\$,not \$V_{r_{(rms)}}=\frac{V_{r_{(pp)}}}{any \ number}\$?
Q2
In the 3. and 4. formula,how is the \$2.4\$ calculated? i mean,based on what reason,so we can say \$V_{r_{(rms)}}=\frac{2.4V_{DC}}{R_L C}, \$and Ripple factor \$=\frac{2.4}{R_L C} \times 100 \% \$ not \$V_{r_{(rms)}}=\frac{any \ number \times V_{DC}}{R_L C} \$ or Ripple factor \$=\frac{any \ number}{R_L C} \times 100 \% \$ ?
tester_ga
  • 43
  • Q1 - [RMS of a triangle wave](https://electronics.stackexchange.com/questions/499312/calculating-rms-of-simple-waveform/499343#499343) – Andy aka Jun 08 '20 at 11:03
  1. The ripple can be approximated by a sawtooth. The ratio of peak to RMS of a sawtooth (proof involves a bit of calculus and is left as an exercise) of a sawtooth is Vr(pp)/(2\$\sqrt{3})\$. Keep in mind that the ripple goes plus Vr/2 and minus Vr/2 so you need only integrate one half of the triangle.
  2. If you assume a constant current from the load and the period of a half cycle, and the above formula you get a constant of 2.41 milliseconds. That should give you a hint of what units to use for C.
Spehro Pefhany
  • 376,485
  • 842
