I have an op amp circuit using the OPA2626 that has a built-in input/output ESD protection of +/-3000V human body model. The circuit is 3.3V single supply, non-inverting, with only an external battery connection. However, it can have a large electromagnetic input to the amp due to a parallel coil with magnetically induced voltages of 10-40mV in normal operation. The main threat may be a magnetically induced voltage spike at the sensor, but do not know at what amplitude. The sensor may see some electrostatic spikes also from nearby objects albeit will have some ferrous-like shielding.
The op amp circuit input is low impedance under 100 ohms. The op amp circuit output is clamped with a zener at +3.3V and continues into an AVR (Atmega) digital pin that is pulled down. The input for the Atmega is between 10 KOhm-100 KOhm.
What add-on ESD should I consider for the input and the output?
Found this excellent post, but still a bit confused about the solution for the op amp w/ESD vs op amp w/out ESD as far as protecting that mA amplitude gap below the ESD's operating range:
"Therefore, the most we would need to do is limit the ESD diode current to <100mA and all will be well. If we suppress the 8kV to about 250V (as shown by the test curves above), then as the supply is negligible relative to that, an input resistance of 250V/100mA = 2.5k would do the job. Note, however, the source of our input bias current: The amplifier input bias current is the leakage current of these ESD diodes. This leakage is a function of the temperature and common mode voltage of the amplifier, as shown in the Typical Performance Chacteristics."
ESD protection for OpAmp inputs and outputs
Edit: added the circuit. L1 will have a ferrous EMI protection from the outside influence. The output of the op amp is limited to the upside at 3.3V via zener diode.
