I was trying to solve a problem from SEDRA-SMITH book. I got stuck so I refer to the solution. When Studying how the author solved the problem I got even more confused.
Let's refer first to the given vbe and ic in the question. As per the explanation in the earlier chapter of the book these givens are instantaneous values.
Here's the first part of the solution. This is only the part I need to understand.
the part of the solution that I don't quite understand is the equation for vbe1. I suppose this is a DC value. An uppercase letter is used for the symbol and the subscript. But if that is so, the equation does not agree with the equation for the instantaneous vbe that is
Following the above setup the equation for vbe1 should be something like this
One other thing that confuses me is the use of 4.8 mA in the second term of the VBE1 equation. Isn't that supposed to be Is? How is Ie equal to Is? From what I understand Is is a very small quantity. Why is Ie used in this case?
