I'm writing a scene for television and I need to make a foam/rope cutter from household items. I've watched several videos, including this one: https://www.youtube.com/watch?v=cM0lP2WCzY0, and determined that I need two sticks (can be anything), two copper wires (for electrical conductivity), a battery to power them, and a "blade" to heat.
Since nichrome wire is not readily found, I'm thinking of using a sharp-edge belt buckle or coiled earring. What material could be a reasonable substitute?
Also, since this cutter is homemade (to use when there are no other options), the copper wires would not have sheath coverings. Would the user be able to handle the device and related shocks, or would this be unrealistic to handle unprotected?
Thank you for your feedback. This is my first post, and we may be looking to work with science advisers on future gadgets, I am happy to discuss further privately.
EDIT: I wasn't expecting so many great suggestions, and I am aware that my question wasn't precise. I will correct in the future. Thank you all.
Hearth
  • 27,177
  • 51
  • 115
    Just to say that it is a good thing that you are seeking expert advice to make the script if not realistic, at least believable. – Sredni Vashtar May 24 '20 at 08:34
  • @SredniVashtar Thank you, that is my goal. Most people here have been very helpful, and I'm learning how an engineer (my character) might problem-solve. – Triple9Nickel May 24 '20 at 14:48
    For believability, please can you provide a little more info on why this is needed? If the purpose is to cut a synthetic rope or anything else, a sharpened belt buckle would go through it in significantly less time than it would take to set up some kind of impromptu heating element. – Graham May 24 '20 at 23:14
  • Why oh why wouldn't you just cut it with a knife ?? – Fattie May 25 '20 at 01:12
    How to build *a Hot Wire* Foam Cutter. What kind of foam? If it *needs* a hot wire, it's not 'foam' it's plastic. Passive foam cutters cut 2" no problem. I ground the teeth off of a saws-all metal cutting bade and use it to cut foam, but that's not for delicate work. – Mazura May 25 '20 at 02:13
  • @Graham Absolutely, this is my first post and I will certainly provide accurate descriptions in future. I have two characters tied up, both female. Their hands can be tied with rope or zip-ties or similar. Kidnappers have taken all of their possessions, so they only have what they are wearing. Jewelry and a belt, so a belt buckle is feasible. I thought it would be a nice touch if the necklace, which was given to her by her electrical engineer father, could be useful in the escape, like the conductor wires (silver, copper, etc). They are in a barn so there can be batteries on the floor. Thanks. – Triple9Nickel May 25 '20 at 02:56
  • @Fattie Their hands are tied and they are in the middle of nowhere without a knife. – Triple9Nickel May 25 '20 at 03:24
  • Please don't completely change what you're asking, especially not after people have answered it. If you want to know how to make a rope cutter, ask a new question--this one is about foam cutters and you shouldn't change that. – Hearth May 25 '20 at 03:25
  • @Hearth Actually, my original post said foam/rope cutter, it was only the title that said Foam Cutter, and I didn't know how this forum worked, so thanks for the slack while I learn my way around. I haven't changed the original post, only made the title more precise. I'll re-clarify. – Triple9Nickel May 25 '20 at 03:30
  • What kind of crazy 19th century household would have a roll _bare_ copper wire laying around instead of isolated cables that comes in lengths with every electronic gadget you buy? – pipe May 25 '20 at 08:30
  • If it's zip ties, then the jewellery can be better used simply to pull back the ratchet bit and let them open the zip ties. As for rope, any sharp object will do. Drop the MacGuyver shit, because it's basically dumb and fake. I wouldn't buy it as a viewer, and I wouldn't pay for it if I was commissioning it. – Graham May 25 '20 at 08:42
  • @Graham Thanks for your suggestions, I'd prefer to burn the rope or zip-ties than to cut them. I disagree that it's "dumb and fake", this show is for a younger audience and I'd prefer to be cheesy and inspiring than to be overly realistic and grim. – Triple9Nickel May 25 '20 at 13:58
  • Why would you not do your own simple experiments? Don't you think that quite apart from the Answer, that would give you enough material for at least one more episode? – Robbie Goodwin May 25 '20 at 18:01
  • @RobbieGoodwin Sure, except I'm not an engineer and I don't understand how this stuff works. I'm here to talk with people much more knowledgable than myself, then I will try something in the real-world. – Triple9Nickel May 25 '20 at 18:11
  • I'm sorry. I thought first that "writing a scene for television" meant writing a scientific lecture. Either way, I suggest it could hardly take more time to do your own experiments - certainly not to ask a search engine - than to crib stuff here. – Robbie Goodwin May 25 '20 at 18:35
  • @RobbieGoodwin It's not a bad suggestion and I will certainly experiment. I just prefer not to burn myself or my house down before learning the basics. – Triple9Nickel May 25 '20 at 19:04
  • Great, Triple9Nickel. That's exactly what you should be telling your audience. Unless you have a good excuse, you should be telling them from experience, not from theory. If you doubt me, why not ask your editor, manager or producer? Why not try that, and Post back what any of them says? – Robbie Goodwin May 25 '20 at 19:07
10 Answers10
20
"Cut the foam! Cut the foam!", she cried as she wriggled and squirmed in the styrofoam dishwasher packaging she got stuck in.
"With what?", cried Bob as he scanned the kitchen for something suitable.
"With a hot-wire styrofoam cutter, of coarse! You'll need about 50 cm and a couple of hundred watts.", said Alice.
"There isn't one in the cupboard.", said Bob. "But wait - there's a toaster!"
Whipping out his Swiss Army knife he unscrewed a couple of Philips screws on the bottom, ripped off the covers and bent out one of the element panels. Deftly cutting through the panel's insulation he was able to pull out about 50 cm of wire. He had his hot-wire foam cutter. Now he just needed to avoid electrocuting both of them.
He put the disassembled toaster on the floor, grabbed the silicone oven mitts and two forks to hold each end of the wire. Stretching it as taut as he could he depressed the toaster lever with his foot.
"Don't move!", he said as the element quickly turned red hot. The radio which had been on all the time bizarrely started to play Buffalo Springfield's Down to the wire. He pressed the hot wire against the foam and it started to cut right through. Bob had forgotten about the smoke and the smell but carried on until he was within an inch of her skin. Kicking the toaster he turned off the power and breathed a sigh of relief. He grabbed Alice's hand and yanked her out of the packaging breaking the remaining bits.
"That's the last time I'm playing hide and seek with you.", he said as he wiped the sweat from his brow.
Maybe I'll stick to electrical engineering. And maybe this isn't a good "how-to" for a TV show.
Transistor
  • 168,990
  • 186
  • 385
  • Comments are not for extended discussion; this conversation has been [moved to chat](https://chat.stackexchange.com/rooms/109124/discussion-on-answer-by-transistor-film-tv-question-how-to-build-foam-cutter-fr). – Voltage Spike Jun 09 '20 at 18:46
It is difficult to imagine that someone would need to cut a rope rather than untie it if they have sufficient mobility and use of their hands to construct an apparatus like the one in the YouTube video.
However if we set aside all other alternatives and imagine that something equivalent to the YouTube device is essential and must be made with materials and tools found in the average home, it might be possible.
Copper wire for connections, tape and some type of small battery should be easy to find. Shock will not be a problem at 12 volts and less. Burns and fire from the copper wire should not be a problem with small batteries and not too much current used for the cutting wire. An automotive battery could be dangerous if not used very carefully. It could supply enough current to make any household-sized copper wire very hot.
For a heating element, you could try the soft iron wire in a twist tie. When heated, it could oxidize and break quite quickly, but it is worth trying. Another alternative is the spring in a ball-point pen. That is probably soft enough that it can be straightened without breaking. A paper clip is worth trying also, but it may be too thick. Remember that the copper wires will get too hot if the cutting wire takes too much current. Modern picture frames often have loops or notches on the back for hanging, but many are still hung using a steel cable across the back. That is not likely to be stainless, but it might work. Stainless cables are used to suspend some light fixtures from the ceiling and between the posts of stair railings etc. Cables would need to be cut and unraveled. Your average Swiss Army Knife might not do that, but the best SwissTool and Leatherman might.
Only the thinest wire will get hot enough with the current that a 9-volt battery can put out. D-cells may be the best. Start with just one. If one will not push enough current through the steel wire, try more connected in series. You can probably tape several in series to something that will keep them lined up. It may be difficult to keep them connected together securely. Perhaps there is a flashlight around that you can hack.
Test of Twist-tie Wire
The wire from the twist tie was about 4 inches long and 0.015 inches in diameter. The resistance was about 0.75 ohms. Three D-cells were able to push about 4 amps through the wire. The internal resistance of the battery, the resistance of the connecting wires and the temperature of the twist-tie wire affected the results.
The wire got hot enough to cut through a 1/4-inch nylon rope.
Another Test
Here is a test with one of those battery holders that holds three AAA cells in the little LED flashlights that are commonly sold for little more than the price of a small package of AAA cells.
The left end of the wire is captured by the spring that contacts the negative end of the holder. The right end is held against the positive end of the holder with my thumb with a little piece of cardboard to prevent burning my thumb.
The wire didn't get quite hot enough to cut the rope. The AAA cells apparently have too much internal resistance / not enough voltage. It might have worked with fresh batteries. Something like this might work with AA or C cells, but making the series cell connection and the connection to the steel wire might be quite awkward.
Success!
The secret is not to distribute the battery power over too much wire. I wrapped all but an inch of the steel twist-tie wire around the ends of short pieces of copper wire. I believe it is AWG 18. A single AA cell got the steel wire red hot as shown below.
  • Thank you for the thorough response. I understand about the thinnest wire. So if I use a 12 volt, could you imagine a thin large hoop earring (or similar) working for the "blade" in place if the stretched wire? The reason being, you are correct, they will have limited hand mobility, so I figured at "pre-shaped" large hoop design is better than them having to stretch a coil. Also she will literally be wearing an earring, so I'd love to use things she has on her at the time. – Triple9Nickel May 23 '20 at 22:56
  • I am not sure what jewelry components would be believable with the required length, material and thickness. I think the spring could be extracted from a pen about as easily as re-shaping jewelry materials. Extracting the wire from an under-wire bra might be another alternative. However getting it out while wearing the bra might not be realistic. However I have recently seen a TV commercial in which (if I recall correctly) a woman reached into her clothing and pulled the troublesome wire out. –  May 23 '20 at 23:18
  • Okay, the underwire is a possibility, though those are quite thick, which is why I thought of the jewelry. I may be able to use that. One question, does the "cutter" have to be a stretched wire or straight line? Could it not be a large circle/arc shape so long as it's hot enough to burn? That's why I thought the hoop earring might be cool, and I could make up any reason why this hoop is the material it needs to be. – Triple9Nickel May 23 '20 at 23:24
    The wire needs enough length for the resistance to be high enough. Thinner wire has a higher resistance per length. Straight vs. curved is not important. Connecting the wire to the battery could be a problem. Copper connecting wire gets the hot connection away from the battery, but that connection could be difficult to keep together. I would use a ballpoint for the wire and earrings to cover the connection point so that it wouldn't burn fingers. –  May 23 '20 at 23:39
  • Hi Charles, I can't figure out how to attach images or direct message on here. Would you mind looking at this image and telling me if you think this design could work? I can use popsicle sticks or chopsticks to hold the wires taut, I'm mostly talking about the electrical setup. So the wires would be copper, and the earring would be steel? Do the copper wires need to be a certain length relative to the hoop? https://www.dropbox.com/s/xl3nv0jvozcivjg/Screenshot%202020-05-23%2017.58.48.jpg?dl=0 Thank you. – Triple9Nickel May 24 '20 at 01:00
    I think that would work with stainless steel or perhaps titanium. The resistance would be too low for 12 volts. I think a 1.5 volt C or D cell might work. I have an electric igniter device that uses a single D-cell. As I mentioned, connecting the wires would be quite difficult. I cut a thin piece of plastic with a single AA cell and the wire from a twist tie, so I think that is close to what you need. –  May 24 '20 at 02:37
  • Let us [continue this discussion in chat](https://chat.stackexchange.com/rooms/108401/discussion-between-triple9nickel-and-charles-cowie). – Triple9Nickel May 24 '20 at 03:48
  • _"The wire needs enough length for the resistance to be high enough"_ -- um...I guess I'm missing something. Current is what creates the heat. Higher resistance makes current _lower_, not higher. So, "high enough" for what? Is the concern here that resistance will be so low that the wire won't survive long enough to accomplish the task? – Peter Duniho May 24 '20 at 18:57
  • @Peter Duniho; please click the link just above your comment to go to chat. –  May 24 '20 at 20:21
How safe does this have to be? How long does it need to work for?
One possible solution is to disassemble a hair dryer. Leave all of the wires connected as much as possible. Remove the heating element from the mica insulator that the coils are wound on and straighten out a length of the element coil.
Turn the hair dryer onto its lowest power setting. The heating element will get hot.
The heating element may self-destruct unless you use the hair dryer at the lowest possible power setting.
Note that this is dangerous. Be certain the outlet the hair dryer is powered from is protected with a GFCI / RCD. Be careful not to touch any exposed connections or bare conductors.
Be especially careful that the heating element that is doing the cutting does not touch any person or come into contact with any metal object.
Another, safer possibility is to strip a hair dryer for parts. Remove the heating element and remove the coiled wire from the mica insulator.
Stretch the coiled wire straight and measure the total length. Assuming that your Mains voltage supply is 120 Vac, cut off about 1/10 of the total length, plus one inch or so. I'm going to call that cut piece of heating element "Resistance Wire" from now on.
Cut the plug off the end of the AC Mains power cord, cut the cord free from the remains of the hair dryer. Use a pair of nuts & bolts to connect the cut length of resistance wire to one end of the power cord. Insulate the connections so they can't short together.
Use the other end of the power cord to connect to a 12V automotive battery. You can do this in the vehicle or remove the battery from a vehicle to use as a portable cutter.
The resistance wire will eventually burn out but you still have 8 or 9 other pieces of wire remaining from the original heating element.
Depending on how much time your character has available, this 2nd approach is much safer that what I first proposed.
Dwayne Reid
  • 23,390
  • 35
  • 67
    Hi Dwayne, it only needs to work one time, and I'm okay with them "getting lightly burnt" for the sake of escaping, since they would perish if they did not escape in this scene. They are in a remote barn setting with no electricity. So I'm hoping to either use jewelry that they are wearing, or the rare item found in a tool shed. I figured they could find a 9v battery because from my research, "building" a battery from coins requires more time and materials than they would have (i.e. sandpapering the copper face off of a penny to reveal the zinc, etc.). – Triple9Nickel May 23 '20 at 20:28
    Toaster comes to mind too. – winny May 23 '20 at 20:38
    Classic rectangular 9V battery (PP3 in the UK) won't have enough power. Car battery would work, but might be overkill... –  May 23 '20 at 20:54
    Simply using a 9V battery to perform such a feat in a movie would be unrealistic at best. It simply can't do it. So I don't recommend it. Many people these days tinker enough with electronics and batteries to know that is the case, and would think of it as a joke. I feel the effect should be more dramatic, in order to not encourage people to short batteries at home. Shorting wrong types of batteries, such as lithium ion, NiMH or car batteries can melt wires, start fires, battery explosions, and cause injuries. – Justme May 23 '20 at 21:33
  • @Justme Okay thank you. If I need to create enough of a hot metal surface to cut a rope, do you recommend I beef up my initial "foam cutter" idea using a car battery? Ideally I need to create a blade in the middle of nowhere to help someone cut themselves out of being tied up. – Triple9Nickel May 23 '20 at 21:40
    a fresh 9V battery can make about 2A into a short circuit. it could probably operate a small foam cutter for about half a minute. 18650 cells as fouind in usb powerbanks and vape modules may be more powerful. – Jasen Слава Україні May 24 '20 at 07:52
    @Triple9Nickel if they're trapped in a barn, a convenient tractor should have a starter battery of 12V or maybe 24V if its diesel. Or a portable "start-cart" common in farms. Or a 12V car battery "charging on the work bench" or even wreck an old (mockup) crank-handle telephone which could produce from 6 to 120VAC according to http://www.oldphoneman.com/FSMagnetos.htm – Criggie May 25 '20 at 01:52
    @Criggie Yes I can have a tractor battery charging on a workbench. Thank you. – Triple9Nickel May 25 '20 at 03:32
Stainless steel wire works and is better than nichrome in some aspects. It is cheaper and stronger than nichrome, and stretches less. So you you can put it under more tension for cleaner cuts and and tension springs are not as important. It is not as high resistance as nichrome but is still higher than copper so you do not need unreasonably low voltages to not overheat. It oxidizes more easily than nichrome but that doesn't matter for occasional use.
Do not use copper wire. Expensive, weak, oxidizes, and too low resistance,
Buy stainless steel wire from fishing or hardware stores. Do NOT use the power from the mains without running it through a power supply or transformer of some kind to step down the voltage. You want adjustable too or else it will run way way too hot.
Using a wall wart might be most convenient. Will need adapter clips to convert the barrel connector to something you can clip to other stuff.
DKNguyen
  • 54,733
  • 67
  • 153
  • Ok thank you, I'm by no means electrically proficient, but I was assuming copper is a better conductor for the battery to heat the "blade." What material wire is typically used in a 9v battery connector? – Triple9Nickel May 23 '20 at 20:25
  • Lower resistance is better if the wire is transmitting power to a load. But here the wire IS the load so you want it to heat up. – DKNguyen May 23 '20 at 20:26
  • Ok in the video I linked above, there is a Nichrome "wire blade" and also a 9v connector with red and black wires. These are not both the same material, correct? I meant to ask, what material is in the red and black battery connector wires. Is that also nichrome? – Triple9Nickel May 23 '20 at 20:31
    @Triple9Nickel Low resistance copper wire to efficiently (i.e. cold) get current to the resistance wire that is supposed to heat up. It could be resistance wire all the way but everything would get hot then (it could be copper all the way too but everything would get hot as well. The relative resistance difference between materials matters as much as the actual resistance). – DKNguyen May 23 '20 at 20:32
    You don't need clips just rip the barrel connector off and twist wires together, you want about 5A for a foam cutter, so a wall-wart may not work well. – Jasen Слава Україні May 24 '20 at 08:24
    One design for cheese slicers uses a stainless steel wire, and they are reasonably common household items. There are other similar "slicing" devices that can be found in the kitchen (e.g. egg slicers). So the stainless wire idea seems like a good one. The wire from a cheese slicer is also a lot more accessible than e.g. that from a toaster or hair dryer, as the wire is usually designed to be user-replaceable. – Peter Duniho May 24 '20 at 18:59
    @Triple9Nickel Also, old violin E-strings. – DKNguyen May 24 '20 at 19:02
  • @DKNguyen Ok that's a great idea. Now, for the "wires" that connect the battery to the "cutter blade", is silver or copper better? Like if the girl is wearing a necklace made of ____, she could break the necklace and connect them from the blade to the battery. I know this is not ideal, but I'm thinking for emergency, what is possible. Thanks. – Triple9Nickel May 24 '20 at 19:13
    You could just use the same wire for everything. It would just all get hot but you have need a wire holder anyways. Silver wire is best better but never used because expensive and copper is much cheaper and almost as good. Copper is valuable enough that we have copper thieves that steal wire. Imagine if it were silver, – DKNguyen May 24 '20 at 19:15
  • @DKNguyen Okay that's very helpful. So if the girl was given a silver necklace (that her electrical engineer father gave her), that's believable. When you say use it for everything, you mean it serves as both the wires connecting to the battery, and the blade itself. So it's like U shape, and the ends connect to battery, is that right? – Triple9Nickel May 24 '20 at 19:24
  • @Triple9Nickel I would actually just use two sticks, one in each hand. Remember I mentioned tension springs? Wire expands and heats. Also, if silver is better wire for transporting energy, but if you want to heat it to cut with it, copper might be better if it is stronger (I do not know which is which). – DKNguyen May 24 '20 at 19:27
  • @DKNguyen For the sticks, you mean to stretch the wire, yes? Understood. But I still need some kind of conducting wire to connect the battery to the blade, so that's why I asked about the jewelry. – Triple9Nickel May 25 '20 at 03:01
  • Let us [continue this discussion in chat](https://chat.stackexchange.com/rooms/108433/discussion-between-triple9nickel-and-dknguyen). – Triple9Nickel May 25 '20 at 03:09
This setup is unsafe, but assuming it's an emergency.
A hairdryer will have two heating coils in it remove one of them and use some of it use it to construct the cutting wiret use an equal length to construt a shunt element, wire the shunt and the cutting element in parallel and connect this parallel combination in series with the hair dryer
The cutting wire element will get about half its normal current, but because it will get no wind it will still get very hot. plenty hot enough to cut foam do not touch the element or the conductors that feed it. the best that can happen is you blow an ELCB the worst is electrocution.
You probably want to get your art department to fake this using a safe DC power supply instead of exposing actors to this potentially unsafe setup. although if ypu power it from an isolating transformer that would significantly reduce the risk.
  • Thank you @Jasen, that's very helpful. I mentioned in another answer thread that I'd like to have the character use jewelry they are wearing to assist in the device, such as wires from a necklace they are wearing, or a earring/belt buckle to act as the cutter. Not sure if these are possible. – Triple9Nickel May 24 '20 at 14:44
Err on an E string
If your household has a guitar about, the strings may be a suitable cutter-wire. You'll need approximately 12V at 2A DC.
From https://www.instructables.com/id/Guitar-String-Hot-Wire-Cutter/
There's a heap more documentation at the linked website https://www.instructables.com/id/Guitar-String-Hot-Wire-Cutter/ but you need either an electric guitar or a steel-strung guitar. If there's nylon strings then this won't work. Also the thinner strings will have higher resistance and will heat up better - so don't use a thicker bassier string.
(leaning a bit on worldbuilding) if there's urgency in the moment, one might cut the other five strings, then stamp on the neck to shatter the guitar, connect the supply to the remaining strings, and have a ~1 metre long cutter-wire with some handles that won't get hot. Plausibly finding 12V at 2A in a hurry might be explained by other guitar equipment.
Hypothetical follow-on, what size string would it take to cut foam if it were connected to mains voltage AC without blowing the circuit's fuse ?
Criggie
  • 754
    Very thinn and long. 120 V would be much easier than 230 V, obvi... – winny May 25 '20 at 06:46
    If you combine this with a simple analog railway transformer you might have something plausible. – Jeroen3 May 25 '20 at 08:31
    IIRC, effects pedals use 9V. You can possibly connect several of these together, however the batteries internal resistance might be too high for this to work correctly (unless alkaline or rechargeable). A wall-wart capable of powering several pedals might be powerful enough. The heroes could rip the plugs off the guitar cables to wire it up. https://electronics.stackexchange.com/ will be able to assist with the details of the batteries. – CSM May 25 '20 at 08:48
If you take the wires suggested in the other answers attached to an old analog model railway transformer you'd have a plausable scenario.
A few inches of toaster wire will probably heat up when using a low voltage variac (which is what those transformer are). And it is safe to touch.
Much safer to show than using a live toaster, you know... copycats. Even though the story of Transistor is nice.
It is plausable, but may not be very usable. Does it have to be?
Jeroen3
  • 21,976
  • 73
That video has very thin wire, much thinner than is used in common heating appliances like toasters and hair dryers.
You might find the right gauge of wire in an electric blanket
I use an old soldering iron (low power) for cutting foam. The cut is wider than a wire, but it is easy to guide as it requiere some force to cut thru material.
It is an household item? Well, yes. I use them for minor repairs, like toys and remotes (battery wires getting unsoldered from PCB).
Candid Moe
  • 209
I have in the past (in the past few weeks, honestly) used an old computer power supply and the thinnest steel fishing wire I could find at the hardware store. It's not exactly a household item, but it's quite possible that it's laying around. As mentioned elsewhere, any stainless wire should do.
Wrap one copper wire around the barrel of the plug, and put the other one inside (balled up if needed to keep it there), wire nuts for the other end.
The wire needs to be sufficiently long, as modern power supplies with cut out if they see too much current. 2-3 feet is usually sufficient.
Brydon Gibson
  • 233
  • thank you for the suggestion. How would you revise this using batteries? – Triple9Nickel May 25 '20 at 14:00
    A car battery would push the voltage you need, as would two 9v batteries clicked together. Most modern cordless tool batteries need to be talking to a "smart" device in order to push any current, but you can crack them open with a screwdriver and tap the 18650 cells directly. Two airsoft gun batteries in series, ~12 alkaline cells (A,C,D), 4 cellphone batteries, 4 watch batteries (though not for very long) – Brydon Gibson May 25 '20 at 14:08
