So what exactly is a polygon island in altium and why is it generally considered bad? How can they be removed from the PCB?
Voltage Spike
  • 75,799
  • 80
  • 208
  • Related: [PCB Design - Polygon pour remove islands or not?](https://electronics.stackexchange.com/q/48677/6334) – The Photon May 23 '20 at 16:31
Islands are floating pieces of copper in the PCB, in most designs they are harmless, in some they are not. In a vacuum such as space space radiation can charge any floating piece of metal and cause it to discharge and damage materials and electronics. So, no islands for space designs.
They can be removed by checking remove islands or:
Remove Islands Less Than
Remove any areas of copper that are less than the specified area. This option is area-based only; it does not consider if that island is connected to a pad or via. Note that all small unconnected areas of copper are always removed if the Remove Dead Copper option is enabled in the Properties panel. Source: https://www.altium.com/documentation/altium-designer/pcb-obj-polygonpourpolygon-pour-ad?version=18.1
Voltage Spike
  • 75,799
  • 80
  • 208
So what exactly is a polygon island in Altium
This is explained in the online documentation:
It's a small part of the polygon that is unconnected to the rest of the polygon due to other objects like tracks or vias.
By checking the box for "remove islands less than" and choosing the maximum island area in the polygon properties dialog.
The Photon
  • 126,425
  • 159
  • 304
