18
Resistivity is defined in units of \$\Omega \times \textrm{cm}\$. I don't conceptually understand what is meant by the unit.
If it was \$\Omega / \textrm{cm}\$, that would be easy to understand - a certain number of ohms for every centimeter. How can one understand \$\Omega \times \textrm{cm}\$?
Transistor
  • 168,990
  • 186
  • 385
elile
  • 305
Imagine a block of material with a uniform density to it. Something like this:
The material also has, let's say, a uniform "resistivity" to it.
Now, suppose we cover the entire face pointed at by the arrow, and the face opposite to it that we cannot see, by plating them with silver (which is very conductive.) We then measure the resistance between these two silvered faces on opposite ends using an ohmmeter. There will be some value for that in Ohms.
Now, let's consider three modifications:
  1. Suppose we doubled the length. Here, since the silvered faces touched by the ohmmeter have the same area as before, but are further apart, we should expect that the resistance we'd measure between the opposite X faces would double.
  2. Suppose we doubled the height. Here, since the silvered faces touched by the ohmmeter have doubled in area but are the same distance apart as before, we should expect that the resistance we'd measure between the opposite X faces would be cut in half.
  3. Suppose we doubled the width. Here, since the silvered faces touched by the ohmmeter have doubled in area and are the same distance apart as before, we should again expect that the resistance we'd measure between the opposite X faces would be cut in half.
So, we postulate the following about the resistance we'd measure:
  • \$R\propto \text{Length}\$
  • \$R\propto \frac1{\text{Width}}\$
  • \$R\propto \frac1{\text{Height}}\$
  • \$\therefore R\propto \frac{\text{Length}}{\text{Width}\:\cdot\:\text{Height}}\$
Now, if we call the length, \$L\$, the width, \$W\$, and the height, \$H\$, and introduce a constant of proportionality, we can say:
$$R=\rho \cdot \frac{L}{W\cdot H}$$
Let's now express the above only looking at the SI dimensions:
$$\begin{align*}\Omega=\rho \cdot \frac{\text{m}}{\text{m}^2}, &&\therefore \rho=\Omega\cdot\frac{\text{m}^2}{\text{m}}=\Omega\cdot\text{m}\end{align*}$$
Just simple dimensional analysis.
jonk
  • 77,059
  • 73
  • 185
    My car's fuel economy has units of area (say 8.1 liters/100km), which is roughly AWG 28. Physical interpretation is a thin cylinder of gasoline consumed as the car moves forward. – Spehro Pefhany May 21 '20 at 03:14
    @SpehroPefhany Yeah. And torque has units of Joules but really is Newton metres and isn't a scalar, but a vector besides. But this doesn't injure what I wrote. – jonk May 21 '20 at 04:22
    Not at all (+1), torque having units of work is a good one. – Spehro Pefhany May 21 '20 at 04:23
    @SpehroPefhany Torque should probably be read as Joules per radian, I suppose. Radians are unitless -- but still important despite it. Dimensional analysis has a lot of subtle corners. We spent many many hours in my high school physics class applying it scaled modeling problems (like, you find you need crazy-minded fluid characteristics for a scale waterfall where you first imagined just using water only to find out you can't.) – jonk May 21 '20 at 04:43
  • Yes, like 1/s for angular velocity. I suppose there's a physical interpretation for voltage V =\$ kg\cdot \text{m}^2/A\cdot \text{s}^3\$. – Spehro Pefhany May 21 '20 at 04:49
  • What is the principle that allows us to halve the resistance if we double the terminal area? – elile May 21 '20 at 04:50
    @elile Twice the conductance. Two equally conductive paths driven by the same EMF (volts per meter) will have twice the conductance of just one of them, separately. The resistance is therefore half as much. (That is, without introducing other problems. It's always possible to hypothesize edge-case scenarios which may complicate such questions. But these are very rarely encountered in practice. Usually, they only happen when scientists intentionally create those circumstances to see what then happens.) – jonk May 21 '20 at 08:38
  • yeah, unit cancellation is _weird_. I stumbled upon even more extreme example when measuring primary cells' capacities, and sorting them by "best bang for the buck", a typical unit of this is "Wh/$". Then I thought, if you'd multiply that by your hourly pay ($/h), units cancel, and you end up with just watts. The interpretation of which is "how large load, in watts, can you afford to keep running if you devote all of your pay to buying batteries to power said load". – anrieff May 22 '20 at 07:10
  • There's also [Ω/sq](https://en.wikipedia.org/wiki/Sheet_resistance#Units), which tends to bend the mind even more than ohm-cm. – J... May 22 '20 at 10:36
  • I mean, I know that all the units are correct and work out, but to me example 1. means that the unit should be ohm/cm. Ohm per cm: you double the cm, so you double the ohm. It doesn't intuitively explain ohm.cm to me. – BrtH May 22 '20 at 12:09
  • @jonk can you help? https://electronics.stackexchange.com/questions/500615/transistor-differential-comparator-thershold?noredirect=1#comment1278683_500615 – G36 May 22 '20 at 16:45
  • @jonk I wonder if you would have any interest in using the (fairly common) bracket notation for dimensions in your last equation? $\Omega = [\rho] \times\mathrm{\frac{m}{m^2}}$. (Very good explanation in your answer BTW) – David Z May 22 '20 at 18:35
To understand this, you must first know that resistivity is basically the total number of resistance per unit length AND cross sectional area.
$$ \frac{\Omega}{\textrm{cm}} \times \textrm{cm}^2 = \Omega \times \textrm{cm} $$
where
  • \$\Omega / \textrm{cm}\$: value of resistance per unit length
  • \$\textrm{cm}^2\$: cross sectional area
WoJ
  • 507
Lutz Fi
  • 377
  • If you say that the bigger the cross section is, the higher the resistance is, that's incorrect imho... – Déjà vu May 21 '20 at 12:41
Another way to think about this repeats essentially the same dimensional analysis as what jonk wrote above, but it starts from Ohm's law which can be written more generally as:
$$J = \frac{E}{\rho}$$
where \$J\$ is the current density, \$E\$ is the electric field and \$\rho\$ is the resistivity. This is always true while \$V=IR\$ is actually rarely true. However, if we keep it simple and consider the rectangular prism that jonk describes above, we can consider the material to be isotropic (meaning the resistivity is the same in all directions), and we have:
$$J = \frac{I}{A} = \frac{E}{\rho}$$
where \$I\$ is the current above and \$A\$ is the cross sectional area. This can simply be rearranged:
$$\rho = \frac{E\times A}{I}$$ Looking at the RHS and doing SI units analysis (fudging dimensional analysis a bit) gives:
$$ \require{cancel} \frac{[\frac{V}{\cancel{m}}][m^{\cancel{2}}]}{[\frac{C}{s}]}= \frac{V}{Amp}\cdot m = \Omega\cdot m$$
Here we have used the usual units of volts per meter for electric field, and coulombs per second for amperes. The best way to think about resistivity or conductivity is that it translates an external electric field into a current density inside of a material with free charge carriers.
In electromagnetic theory, units are sometimes highly confusing and it's better to focus on what the quantity means through fundamental equations. As food for thought, consider that in Gaussian units, the resistivity is measured in seconds! You could rationalize that as a time required to travel unit length in response to an applied field, etc, but I still think it's better to stick with the fundamentals.
Danny Bubb
So if \$\rho\$ is given as \$1.6 \mu\Omega-\text{cm}\$ (copper)
If you consider a strip 1cm long and 1 cm wide, it's the thickness of the strip in cm to make it \$1 \mu\Omega\$ in resistance.
Spehro Pefhany
  • 376,485
  • 842
If we start with restistance as relating to a particular thing, say a length of wire of length 10cm. It is measured in Ohms.
Now, the wire manaufacturer will probably specify the wire as 99% copper, with a specificed resistance in Ω/cm. That is a slightly more abstract concept. If we put two resistors in series, we know the resistance is doubled.
For a physicist the interest is more about the properties of 98% pure copper in general. So far we have a quantity that depends on the gauge of the wire. To a good approximation the resistance is inversely proportional to the area: a good way to visualize that is to imagine we have a stranded cable, so a thicker cable is just more strands in parallel. This gets us Ω.cm.
It's not easy to visualize units like that. One thing that might help would be to think of the resistance between two faces of a cube of copper. It would decrease as the cube grows. Maybe it's easier to think of the conductivity of a material having units of S/cm (where S = Siemens aka mhos)
richardb
  • 101
