I am planning to install a PCI Express Wifi-adapter in my PC. In order to do this, I would need to open my PC. I'm worried that if there is static electricity in my hands it could fry the motherboard.
I don't have an anti-static wristband, nor do I have an ESD mat. Is there a still a safe way for me to install the PCI Express Wifi-adapter without frying the motherboard?
O S
  • 131
You worry too much. Go to an area with least possible sources of static electricity, e.g. no carpet. The adapter most likely comes in a ESD bag. Open the PC and touch the PC metal parts while holding the adapter bag, take out the adapter, hold the metal bracket, touch the PC metal case again, and there should now be no potential difference between the adapter, you and the PC. Mount it in the slot and close the PC. Done.
Justme
  • 127,425
  • 261
You could use a bare copper wire that you wrap around your arm/leg and connect to something which is connected to ground like your radiator.
    Works great until you touch a live part and can not let go of that wrap around. Should be a painful death. There is a 1 megaohm resistor in series with comercial hand straps for this very reason. – winny May 22 '20 at 10:10
