Yesterday I had laptop charger opened and take a closer look at it. And went for capacitor because it looks damaged. Then the new capacitor is replaced, plugged in and doesn't work. I don't know if the MOSFET is dead but I saw smoke coming out. The capacitor is charged like almost full and it's getting messy dealing with the circuit. Can I discharge the capacitor safely with a resistor? Ff so, what value/wattage of resistor should I choose for discharging 450V 47uF capacitor?
Asked
Active
Viewed 1,082 times
10 kohm? But if you leave it in circuit for a while, it will most likely discharge itself. Measure the voltage with a multimerer and report back! – winny May 15 '20 at 14:44
I have 10kohm. Though I have only 1/4 wattage of them. Won't they burn if I leave it in the circuit ? – Saji May 15 '20 at 14:50
Oh, that's a bit too low. P=U^2/R. For 0.25 W and 450 V, the limit would be 810 kohm, but in practice there is not enough energy in the capacitor to smoke the resistor as analogsystemsrf stated below. 100 k is probably fine. – winny May 15 '20 at 14:57
What about the wattage ? won't it smoke the resistor ? It's only 0.25W :3 – Saji May 15 '20 at 15:04
Should be fine with 100kohm and 0.25W rating for your capacitor. Measure the voltage first with your multimeter! – winny May 15 '20 at 15:06
somewhat related: [Do capacitors automatically release their energy over time?](https://electronics.stackexchange.com/q/32529/7036) – Nick Alexeev May 18 '20 at 03:39
The capacitor stores 0.5 * V * V * C = 200v * 200v * 0.000047
Energy = 40,000 / 20,000 = 2 watt seconds. (oops forgot the 0.5 === ONE watt second)
Thus a 1 watt resistor should easily survive, of any value.
Consider a 10 ohm. The time constant will be C * R = 47 * 10 = 470 microsecond.
The current will be 200 volts / 10 ohms = 20 amps peak.
The power (peak, at start of the discharge) will be 200v * 20a = 4,000 watts.
But the discharge tails off very rapidly.
You can write the integral of the energy, time = 0 to time = infinity.
analogsystemsrf
- 33,703
- 2
- 18
- 46
I have higher value resistor but all of them 1/4 wattage. Though I can parallel the resistor for wattage boost maybe ? Currently have 100k ohm, 47k.. – Saji May 15 '20 at 14:48
What would happen if you short it with a screwdriver besides the screwdriver heating up? – Swedgin May 15 '20 at 14:51
It is a bad idea. You may end up damaging the capacitor. That is what they say xD – Saji May 15 '20 at 14:53
@Saji who is `they`? I'm genuinely interested in this, since I would just short them – Swedgin May 15 '20 at 14:56
It can also be dangerous to short with a screw driver at this voltage. Beside damaging and creating sparks. You can solder 4 x 10 ohm resistors in serie. Or several 47K in parallel (in order to have more than 1W). – Fredled May 16 '20 at 07:05
