I need to design a totem bole bjt based gate driver for Mosfet IRF640, which is going to be used in a Buck converter.
I know the peak gate charging current= 1A.
I've already selected my complementary Bjt pairs (2N2222A,2N2907A) so it can give a max current = 0.6A.
The mosfet has a minimum \$V_{gsth}\$ = 2V and max of 4V. Now how do I select Rg? Rg = [Vgg - V(gs,Io)]/ig.
From the equation:
1.On no load, I get Rg = [15-4]/0.6 = 18.33 ohms
On full load (Id=10A), V(gs,Io)=5.5V from datasheet, so Rg =[15-5.5]/0.6 = 15.84 ohms.
Considering -Vgg = -5V, I get Rg = [15-2-(-5)]/0.6 = 30 ohms.
Where should I use the peak gate charging current value of 1A?
Thanks in advance.
