Microelectronics Circuits by Sedra/Smith says,
As in silicon diodes, the voltage across the emitter–base junction decreases by about 2 mV for each rise of 1°C in temperature, provided the junction is operating at a constant current.
$$i_c = I_s e^{\frac{V_{BE}}{V_T}}$$
$$\implies V_{BE} = V_T \ln\left( \dfrac{i_c}{I_s}\right)$$
$$\implies V_{BE} = \frac{kT}{q} \ln\left( \frac{i_c}{I_s}\right)$$
It can be clearly seen that when \$i_c\$ is constant, \$V_{BE}\$ is directly proportional to temperature.
Then why does the voltage decreases instead of increasing?
Akash Karnatak
  • 295
  • Short answer: The influence of VT is rather small.....it will be overshadowed by the strong influence of the current Is on temperature. Is rises with temperature T and Vbe must be reduced correspondingly (for Ic=const) – LvW May 13 '20 at 07:53
It decreases because Is is an exponential function of temperature, roughly doubling to quintupling for every 10°C, depending on \$\eta\$.
Much more from this chapter.
The equation for change is derived as follows:
\$dv/dT = \frac{v - (3V_T +V_G)}{T}\$
where Vt is the thermal voltage 0.0259V @ 300K (Vt = kT/q)
Vg is the bandgap voltage for silicon 1.11V
T is the absolute temperature say 300K
so at room temperature of 300K with v of 600mV dv/dT is about -1.96mV/°C
Spehro Pefhany
  • 376,485
  • 842
