I saw some other questions here about DC Block capacitors in LTspice and none of them helped me with my problem.
The question is very simple, why we have a DC offset when using capacitors as DC block in LTspice (even with a parallel resistor)?
The facts:
With Stop time = 10 m (very large!), Maximum Timestep = 0.01 n (very small!):
SPICE log (no floating nodes):
Simulation command:
Is there anything I should fix?
Thanks a lot!
astable
  • Looks like the mean value is about 0, once you take the uneven mark-space into account. What's the specific problem you are asking about? –  May 11 '20 at 21:27
  • Hi Brian, thanks for your comment. The average value is -12.887mV and not zero as expected. I just want an average value equal to zero. – astable May 11 '20 at 21:42
  • @astable It's because of the way that PULSE works in LTspice. Have you read the documentation about what it does when you specify "0" for the rise and fall times and how this relates to the time HIGH and the time LOW? – jonk May 11 '20 at 21:43
  • Hi Jonk, yes. As you can see in the SPICE log these limits are generated automatically. FYI: Limiting rise time of source v1 to 1.5625e-009 Limiting fall time of source v1 to 1.5625e-009 – astable May 11 '20 at 21:47
    @astable Then think more closely, here. The ton is fixed by your requirements. The tperiod is also fixed by your requirements. So the 5% rising edge and the 5% falling edge are subtracted from the toff period. Thus, toff is 40% but ton is 50%. – jonk May 11 '20 at 21:52
  • @jonk That's what I was going to say. :-) Better make that an answer. Also, the defaults are 10% (of `Ton`). – a concerned citizen May 11 '20 at 21:55
  • @aconcernedcitizen I'm fine with you taking point on this, if you want to. I'm not terribly interested, myself. By the way, it appears it is 5% on each edge, as I said. Just checked. Though maybe my calcs are wrong? – jonk May 11 '20 at 21:56
  • @jonk Neither am I. Honestly, the only reason I set out to answer was to get to that ending conclusion about blaming the tool first. OP, here's a question whose answer deals with what you have here: https://electronics.stackexchange.com/a/372282/95619 (2nd paragraph). – a concerned citizen May 11 '20 at 22:01
  • Tested with a sinus and same thing. I put 3.1E-9 (~10%) as Trise and Tfall with PULSE and nothing. Just to make it clear when I wrote a "bug" it was just to say something that I should to adjust in the simulation or an artifact and not a problem with the tool. I'm sure that LTspice is a great tool. – astable May 11 '20 at 22:05
  • @jonk Maybe you calculated the percentage of the total period, instead of `Ton`, and we're referring to different things? To be sure we're on the same track, for example, `pulse 0 1 0 0 0 10n 20n` makes a `1n` edge, while `Ton=5n` makes a `0.5n` edge. – a concerned citizen May 11 '20 at 22:06
  • @aconcernedcitizen Probably my misunderstanding. I thought LTspice used Tperiod. You are saying it uses Ton. I can't recall checking that. So I may very well be mistaken. – jonk May 11 '20 at 22:28
  • @jonk We specify Ton and Tperiod for PULSE type. He's just saying that LTspice calculates automatically 10% of Ton to make the edge. But if I put 31 ns as Tperiod, the half as Ton and 0 for Trise and Tfall, we can see in the Log that LTspice automatically sets it to 1.5625 ns which does not make 10% of Tperiod. – astable May 11 '20 at 22:36
  • @astable I'm beginning to think that, when 0, Trise and Tfall are set to 10% of Min(Ton, Tperiod-Ton). And those "eat into" the off period. Not sure how it handles things if the off period is fully "eaten." – jonk May 11 '20 at 22:42
  • @jonk Yes, you're right. – astable May 11 '20 at 22:48
  • @jonk Yes, you're right. Forgot `Ton` can get larger than 50%. :-) – a concerned citizen May 11 '20 at 22:52
Perhaps we shouldn't trust LTSpice on-screen graphing, but I can't help but suggest that using eyeball techniques, duty cycle is not 50%. I have offset the graph (in orange) to see that pulse width spends more time "high" than "low": enter image description here
glen_geek
  • 23,591
  • 50
  • Wow! Thanks to your eyes of eagle the problem was solved!! You're right. we must subtract from Ton the needs of Trise and Tfall. Due to this difference of Ton and Toff some residual current remained in the capacitor and then it integrated the voltage plus a constant value from before: \frac{1}{C} \int i(t)dt+cte. The average value is always different of zero, but at least +V is equal to -V. – astable May 11 '20 at 23:33
  • seems @jonk got there first. **Ton** gets priority, and seems to be 50%, while Toff takes up the slack from **Tperiod**, so Toff gets short-changed in this case by some part of **Trise** and **Tfall**. – glen_geek May 11 '20 at 23:43
  • Yes, @jonk was right, and when he posted his answer, I didn't understand the relationship between his comment and the integration of the remaining current in the capacitors. I just understood when you showed the graphs. My bad. – astable May 11 '20 at 23:53
  • Nice way to make it more clearly visible. –  May 12 '20 at 12:29
Adjusting Ton to take into account the need for Trise and Tfall the maximum voltage and minimum voltage can be matched. See Glen_geek comment and Jonk first comments for more detail.
astable
Even if you make the source with a perfect average of peak/2, given your circuit you'll still see a tiny amount of DC in the signal because of the resistive network. If you remove any resistances, set any internal parasitics to zero, all, but keep R1 (to allow discharging), the error will be diminished, but then the floating point rounding will have its say. And if you switch to the alternate solver, which is supposed to be about 2x slower than the normal solver, but with a 1000x greater internal accuracy, you'll still see differences because nothing is perfect.
a concerned citizen
  • 21,167
  • 40
    Did you notice the .TRAN card? He's selected only the last 10 ns of a 10ms period. – jonk May 11 '20 at 21:50
  • @jonk Darn it, I missed it, I'll modify accordingly. Thank you. – a concerned citizen May 11 '20 at 21:51
  • @aconcernedcitizen I've tried the alternate solver and also with no resistors before post the question. With these "fixes" I can reduce about 1/10 the average value, but it still strange. The maximum value is 169.02727mV and the minimum value is -206.57188mV. There is always a boring DC offset. I will try to post this question on some forum with LTspice experts. Thank you anyway. – astable May 11 '20 at 23:02
  • @astable Have you certified that the Ton and Toff are equal to each other, yet, in a run? – jonk May 11 '20 at 23:37
  • @jonk Thanks Jonk. The problem was solved. See Glen_geek comment for more detail. – astable May 11 '20 at 23:42
    @astable That's what my very FIRST comment was trying to get you to look at. Glad to see it done, now. – jonk May 11 '20 at 23:43
  • @jonk Yes sorry. I didn't understand the relationship between the current remaining in the capacitor and what you were trying to explain. – astable May 11 '20 at 23:46
  • @astable I had hoped that would be sufficient for the clue (to you, or to others.) +1 to your answer. – jonk May 11 '20 at 23:47
  • @jonk I quoted your comment in the solution. Thanks again. – astable May 11 '20 at 23:48
