I found this device in my father's basement, but I can't figure out what this device is. It has only 1 SCART connector, 1 power cable and only 1 button in front of it. I think it may be some old video decoder, but I'm not sure. These are the images of the device outside, and the circuit board.
4Maybe a test-image generator? It's going to be next to impossible to figure this out without either a model number, or a schematic. – Ron Beyer May 11 '20 at 20:18
Try diving into the datasheets for each of those parts. For ex, the CD4066BE datasheet says "The CD4066B device is a quad bilateral switch intended for the transmission or multiplexing of analog or digital signals.". Hard for me to find info on the other stuff but with some deeper diving you might have some luck.. – Michael May 11 '20 at 20:28
1you should test which cables from the SCART connector are connected to the board. [This](http://hardwarebook.info/SCART) will help. – Marcus Müller May 11 '20 at 20:48
12This is a vintage DIY Canal + decoder ! (Canal + is a French crypted TV Channel) – andre314 May 11 '20 at 21:15
@andre314 Pirate box? – winny May 11 '20 at 21:30
1@winny Yes, pirate. – andre314 May 11 '20 at 21:35
1@andre314 yarr, matey - made me dig in and check. See my answer. – hacktastical May 11 '20 at 21:57
3it is a large paper weight – jsotola May 11 '20 at 21:58
@andre314 Arr mate! – winny May 12 '20 at 13:10
tl; dr: It’s an early Canal+ 'pirate' box (with props to commenters who mentioned that.)
The clue is the set of delay lines. Canal+ was originally based on a scrambling scheme called 'RITC Discret 1', that randomly manipulated video delay in increments of 902ns (0, 902, 1804ns). Four 470ns delay lines (those green Philips things in the photo) would give 1880ns or 940ns in the middle, so fairly close.
More about that here: https://en.wikipedia.org/wiki/Television_encryption#RITC_Discret_1
And here it is being discussed (in French): https://www.smartphonefrance.info/actu.asp?ID=12502
Anyway, so the job of the HC05 is to figure out the current Discret 1 keying based on a reference that's periodically broadcast, then implement the variable delay line-by-line, selecting one of the Philips delay taps.
What happened with this box? With the publication of the design in the December 1984 Radio Plans, it was widely produced, ultimately leading Canal+ to switch to a different scheme.
- 49,832
- 2
- 47
- 138
3Did the video signal go in and out through the single SCART connector using the pins 19 and 20 (composite video output / input)? Did satellite receivers have a dedicated SCART for such an external signal processing? – pabouk - Ukraine stay strong May 12 '20 at 07:15
I wonder (also @pabouk) if it was used with some form of SCART splitter/adaptor cable. I still have a selection and I think I could combine them to get composite in and out of the same plug suitable for this – Chris H May 12 '20 at 08:50
2@pabouk in Europe, SCART was pretty standard on any TV set after say 1993 or so, exactly because VCR and sat set-top boxes had it. Yes, SCART is a bidirectional thing: TV->VCR worked just as well as VCR->TV over the same cable; all pretty standard features! – Marcus Müller May 12 '20 at 13:28
Thank you very much! I think I remember now that it was used in some old Satellite TV configuration, when you have one antenna and multiple receivers. Sadly, today it can only be used for scavenging / spare parts. – brko May 12 '20 at 18:41
The "theory of operation" links point to domains that I assume expired. They currently link me to NSFW dating and cam sites... – Cole Tobin Aug 26 '21 at 01:33
Well, that wasn't very nice of them. I removed the links. Thanks for bringing it to my attention! – hacktastical Aug 26 '21 at 01:58
The green rectangles appear to be delay lines, one IC is an analog switch CD4066BE, one is a quad op-amp chip LM324DP, the yellow sticker is a MC68705 microcontroller, and the right top IC is obscured in the image. I would assume the chip is mostly likely a switch like the CD4066BE. The power side of the system has what looks to be a step-down transformer (I couldn't find the datasheet) with a LM7805 which is a common voltage regulator IC to output +5vDC.
As for the function of the box, it was likely used for video like you suggested. Depending on the programming of the chip with the yellow sticker, it could be used for video decoding. However, it could also be used as a type of filtering box or signal generator because of the delay lines and op-amps which can be used as adders, subtractors, or oscillators (or more of course).
- 384
- 2
- 13
Does the yellow sticker covers up the window that is used for exposing the EPROM to ultraviolet light to erase it? – Jacob Krall May 14 '20 at 03:55
While I couldn't find the exact specification to reset/erase the EPROM, you can generally assume that the sticker covers the UV reset, yeah @JacobKrall – nate May 14 '20 at 04:04
