what is the meaning of ODR (output data rate)
BMI270 says it has 1.6kHz for accelerometer ODR
does it mean internal registers update rate is 1.6kHz
or
1.6kHz/(16bit x 3) = 33Hz ? (here 3 is, 3 axis)
or
1.6KHz/ (16bit) = 100Hz? (per each 16bit register)
oppo
  • 537
True. Think of it to be something like mesurement rate. It'll give you the updated data at a rate of 1.6kHz when you query through SPI or I²C.
Rohat Kılıç
  • 26,954
  • 67
  • so its the maximum sample rate the MCU can achieve? (ODR 1.6kHz = each accelerometer 16bit register update rate = maximum achievable sample rate for accelerometer data is 1.6kHz) correct me if this is wrong – oppo May 11 '20 at 05:57
  • @oppo yes. Even if you query faster it will probably give you the last updated content. – Rohat Kılıç May 11 '20 at 06:10
