What is the simplest way to regulate the min DC voltage in a circuit? Is it possible to do with zener diodes?
Desired performance:
Input > 3.3 VDC Output = Input
Input = 3.3 VDC Output = Input
Input < 3.3 VDC Output = 0.
According to your description, something like this should work:
The TLV3012 has the reference voltage built-in, so that's 1 6-pin IC, 1 FET, and 2 resistors. Not sure if you consider that "simple". :)
Similar:
Using a pMOS to switch a load is summarized here.
You could probably use a Zener as the reference for the comparator, too, or maybe rig something up to drive the MOSFET from the Zener more directly, but I don't know how precise that would be.
If the voltage doesn't have to be quite 3.3V you could use a MAX809 reset circuit. Exists in several voltage versions, closest is 3.08V, custom voltages are possible.
For low power applications (< 20mA) you can use the output directly to power your circuit, otherwise use the output to drive a low \$R_{DS(ON)}\$ MOSFET.
(graph is actually from an MC34064 datasheet, but would look similar for the mAX809)
You can connect a push/pull voltage detector (PMIC supervisor) such as the Microchip MCP112 or TC54 to a logic-level MOSFET, e.g. as described in the TC54 datasheet:
(page 6)
There are some popular thresholds versions of these parts, e.g. MCP112-300, MCP112-315, TC54VC30. So perhaps the nominal 3.15 V tripping point is sufficient for your application. In case it isn't you can look into getting a customized version or use one with V_trip=3V and voltage divide V_In as described in the TC54 datasheet:
(page 6)
For example with V_trip=3V and a target threshold of 3.2V you could chose R1=1780 Ohm and R2=26700 Ohm).
In comparison with the MAX809, the above voltage detectors are more efficient (e.g. I_DD_typ=1µA and I_DD_max<4µA instead of 17µA and 50µA) and implement hysteresis.
