I am attempting to test discharge of a large battery pack. I am trying to set up an arduino that controls the discharge by using a bank of 75W bulbs. I have set up my system like shown in the picture. The issue is that the second I turned on the mosfets with the Arduino the first mosfet blew fairly quickly. In my mind this set up should work, but its oviously not...what am I doing wrong? I'm using some spare FQPF20N60 mosfets I had. From what I can tell the Vgs(th) on this mosfet is 5V and is well under the Vgs which is 10V.
Asked
Active
Viewed 35 times
If Vgs(th) is 5V an Arduino cannot drive them directly. You need to drive them with the Vgs at which the ON resistor is measured : you said 10V. At 5V they don't turn fully on; drop a lot of voltage across the FET, dissipate a lot of power, with the effect you observed. Also, duplicate of many other questions here. – Apr 29 '20 at 19:03
you my friend are a scholar and a priest, I was only finding things related to people paralleling the gate voltages to be able to control it with an arduino but not the other way around, this makes sense. – Dan Hernandez Apr 29 '20 at 19:12
Another factor is that the cold resistance of bulbs is very low - inrush current may be 10 x run current. Nichrome wire eg from an old heater or toaster has nearly constant resistance hot or cold. – Russell McMahon Apr 29 '20 at 20:45
interesting, what about placing an NTC thermistor inline to prevent inrush? – Dan Hernandez Apr 29 '20 at 22:17
@DanHernandez NTC -> You could, but if you want quantitative results from the test then a well defined load may be useful. Bulbs are OK. Nichome is probably better. It's availanble new. but there are many sources of old free Nichrome. If you have say a 1000 Watt 100 VAC element then to run some at 58V at the same load per length you want about 58/110 of a length. Annoying that it's not 50% so you can double it. || BUT as P = V^2/R - using a say 1000 watt element at 58V means power will be (58/110) ^2 x 1000 = 278 Watts. ... – Russell McMahon May 02 '20 at 01:02
... It looks like you want 5 x 75W x 4 = 1500 Watts. |2 x 1 kW 110 VAC elements trimmed to part length in parallel should suffice. You can use mechanical tapping with a clamp. – Russell McMahon May 02 '20 at 01:02
That looks like a 16S LiIon battery (58.8/16 = 3.675)(you should say). If so Vmax is 4.2 V / cell so 4.2 x 16 ~= 68V max and maybe around 50V min. [Lead acid 4S looks less likely (14.7 V/12V battery)]. | Say 60V. battery mean. So use 80% of a 1 kW element x 4. Parallel 2 x 80% lengths to give 750W at 60 VDC. Use two of these in parallel to give 1500 W at 60 VDC. Tapping onto uncut heater or toaster elements allows adjustment to suit. – Russell McMahon May 02 '20 at 01:59
You aren't applying enough gate voltage. See the \$I_d\$ vs \$V_{gs}\$ graph below from the datasheet. At 5V, you only have enough \$V_{gs}\$ to get about 1 Amp, which means the light bulbs only drop about 10 of the 59 Volts. So the MOSFET has 49 Volts across, at 1 Amp. So about 50 Watts of dissipation.
rpm2718
- 2,632
- 1
- 6
- 14
