Hello everyone,
I am working on the prediction of the reverse recovery losses in a Buck converter. I have the following schematic:
You can see below a zoom on the turning-off time of the diode:
Turning-off of the diode
I am using the following models for the MOS and the diode:
  • .model diode d(Is=1f n=1 tt=200p)
  • .model pmos pmos Vto=-0.4 Kp=40u lambda=0.05 tox=5n Cgdo=0.207n Cgso=0.207n LD=30n
Can someone explain me how does SPICE (I am using the latest version of LTSPICE) model reverse recovery time? I am looking for equations, aka a way to predict tRR. In their book Microelectronic Circuit Design (5th Edition), R. Jaeger and T. Blalock speak a little bit about it, p91-92-93-94 and p128-129. They give an expression for the storage time, but with this expression, I can’t predict what SPICE shows.
Can the reverse recovery time can be seen as the time required to empty QD = iDtT the charges stored in the diode? If yes, tRR should be the integral of the negative peak current flowing through the diode right? When I calculate this integral, it doesn’t match QD.
I am not looking for information from a datasheet, I would like to understand how LTSpice is doing its calculation and ultimately, I would like to be able to predict what it is doing.
I haven’t defined parameters CJ (junction capacitance), and RS (series resistance). But still, SPICE does model a reverse recovery effect. How and why?
dtc
  • 83
  • Start [here](http://ngspice.sourceforge.net/docs/ngspice-html-manual/manual.xhtml#magicparlabel-6770). – jonk Apr 21 '20 at 22:52
  • I don't *think* most of the SPICE simulator diode models model reverse recovery, only diode capacitance. There are some papers and models out there that attempt to do it, but pretty sure it's not a built-in feature of the existing standard models. Apparently PSIM has a diode with reverse recovery, and other specialized simulators may as well. – John D Apr 21 '20 at 22:53
  • Hello John, thank you for your comment. I have been told that LTSpice had been modified by Linear Technology/ADI to precisely model a reverse recovery effect, as other versions of SPICE do not model this effect (I read some papers which are dealing with that). If LTSPice doesn't, I should not have this negative peaks, isn't it? – dtc Apr 21 '20 at 23:21
  • Thank you jonk for the manual. There is no depletion capacitance in my model, and I don't manage to explain how SPICE is calculating trr given my diffusion capacitance Cd (an expression is also given in Jaeger's and Blalock's book p93). Still, I don't manage to fit an RC response (Cd and Rchannel ?) approximation to the plot SPICE shows me – dtc Apr 21 '20 at 23:28
  • @dtc Indeed you are correct, it seems they did add a term for soft reverse recovery: "The soft reverse recovery parameter, Vp, adds a dQ/dt damping to diode charge as suggested by K.J. Teng and S. Pan in 'Modified charge-control equation for simulation of diode reverse recovery', Electronics Letters, 15th February 1996 Vol. 32 No. 4." You might look up that paper to see how it's done. – John D Apr 21 '20 at 23:30
  • @dtc That info was from here: http://ltwiki.org/LTspiceHelpXVII/LTspiceHelp/html/D-device.htm – John D Apr 21 '20 at 23:31
  • @JohnD It's nice to point to the ltwiki page, but that's nothing but an extract of LTspice's own help pages... Too often the manual is overlooked. – a concerned citizen Apr 22 '20 at 11:04
  • @aconcernedcitizen I mainly linked the ltwiki as the first source I found for the paper cited. The real answer seems like it would be in the paper. If that info is also in the manual even better. I didn't look at the manuaI as I can't use LTSPICE (at least professionally), since their license agreement prevents other semiconductor manufacturers from using the program. – John D Apr 22 '20 at 15:48
I recently had to research this myself, so I am familiar with some of the nuances here. It can get very confusing because various textbooks/papers/articles mix n' match notations/symbols. So be careful in navigating this topic.
Basically, SPICE doesn't natively model the entire reverse recovery time. It only models the storage time portion, or the first "half" of it. It's a good idea to split the two regions visually. The JEDEC document JESD282B.01 has a good figure for this (Figure 5.23).
Generalized reverse recovery waveforms for condition D
Some definitions of the terms in this image:
\$I_F =\$ The forward current prior to reversal.
\$I_{RM(REC)} =\$ The maximum reverse current peak after reversal.
\$di/dt =\$ The slope of the transition from forward current to reverse current.
\$t_{rrr} =\$ The subscripts imply "reverse recovery rise" time, but this is normally called the storage time.
\$t_{rrf} =\$ The subscripts imply "reverse recovery fall" time, but this is called either transition time or transient time in various texts.
\$t_{rr} =\$ This is what you know as the reverse recovery time as specified in manufacturers' datasheets under certain conditions. It is simply the sum of \$t_{rrf}\$ and \$t_{rrr}\$.
SPICE can only model the \$t_{rrr}\$ portion of this behavior. The SPICE parameter of concern would be the "transit time" and it's the tt=200p in your .model statement for the diode. Relating the two values to each other is not straightforward, because the transit time is also known as the "carrier lifetime" and involves complex solid state diffusion equations. The textbook you referenced offers an approximation for the solution, which is snipped here (from 4th ed.):
The full derivation of this approximation is discussed in the last few pages of this PDF snip (or cached screenshot), which appears to be an excerpt from Solid State Electronic Devices by Ben G. Streetman.
Anyway, if we use this storage time approximation along with eyeballing the current values from your LTspice plot: $$ t_{rrr} = TT \cdot \text{ln} \left[ 1 - \frac{I_F}{I_{RM(REC)}} \right] = 200 \times 10^{-12} \cdot \text{ln} \left[ 1 - \frac{1.6}{-11.2} \right] = \text{26.71ps} $$
This time is rather close to what's shown in your LTspice measurement. If you move your right measurement point back a little bit so it matches with the peak, it's probably even closer.
As for complete modeling of the full reverse recovery time, some simulators include special consideration for including the \$t_{rrf}\$ portion. I also found this paper which details a method for creating a subcircuit, able to be used in any SPICE simulator, which adds modeling for \$t_{rrf}\$. It also expands on much of the things described above.
EDIT: I did more research on LTspice's Vp parameter mentioned in the question's comments. Defining this parameter definitely adds modeling of \$t_{rrf}\$. It appears to always have been present in LTspiceIV, but they didn't add it to the documentation until LTspiceXVII. That could explain why the paper linked above lists LTspice as not supporting full reverse recovery modeling, because this feature was unknown to the author at the time. Regardless, the subcircuit method is still useful for other SPICE simulators, such as ngspice.
Ste Kulov
  • 3,771
