14
While watching this Signal Path video, I came across this shot:
Taken from The Signal Path youtube channel
I saw few rigid coaxial cables there and so I started wondering what might their advantages be. I could only find disadvantages:
  • They're expensive
  • Limited in available angles 45° or 90°. Otherwise they're not easy to bend compared to the other cable types
  • Sold in sections so we may need to always join them
  • Prone to corrosion
The only advantage seem to be higher power capability.
So, are there any advantages to using rigid RF coaxial cables?
HatimB
  • 826
First, the product you show might be semi-rigid rather than rigid cable.
In either case, the main advantage is lower loss, because of the solid outer conductor (as compared to the braided o.c. used in flexible cables). The solid o.c. also reduces radiation, which can be important if there are sensitive receivers nearby.
In a production environment the rigidity of the cable is itself an advantage because it means the system will always be assembled with the cable arranged in the correct way, rather than however the assembly worker can make it fit. The rigidity of the cable also improves phase stability.
Most of the disadvantages you cited can be mitigated, or don't even apply when manufacturing in volume.
Not true at all. There are numerous shops that will bend these cables to whatever angles you like, following your drawings.
Not true. You can have these cables assembled at whatever length you like. Certainly they can be fabricated up to at least a meter in length, which is plenty for the type of system you showed in your image.
Prone to corrosion
The outer surface is typically tinned copper or aluminum. Either of these materials is likely to be present in numerous other locations in an electronic assembly, so these cables will be no more prone to corrosion than, for example, the surfaces of any PCBAs used in the product.
The Photon
  • 126,425
  • 159
  • 304
    Agree with everything The Photon said. We use semi-rigid coax cable assemblies like jellybeans in our products. Almost every one is custom made in so far as length, bends, and connectors are concerned. All of them have specs on them for things like insertions loss and phase matching/stability. We have 120 of them on one of our latest products. – SteveSh Apr 16 '20 at 00:11
    phase stability compared to flexible is perhaps the most important in aplications like VNAs, and low leakage of signals compared to flex in spectrum analysers. – Neil_UK Apr 16 '20 at 05:08
    `In a production environment the rigidity of the cable is itself an advantage because it means the system will always be assembled with the cable arranged in the correct way` - not just production, but also **in service**. Especially for equipment that must be able to tolerate shock and vibration, rigid cable ensure the cable routing stays exactly where it should - especially important if the device generates internal interference where the cables are routed specifically to minimize that interference. – J... Apr 16 '20 at 12:50
  • @J... I believe that is exactly the point of that paragraph. – Toothbrush Apr 19 '20 at 16:46
  • @Toothbrush, No I hadn't thought of that specifically. J's point is a good one (although I'd go more with Neil's reason to minimize phase variations. I've never seen a flexible cable flop around enough to really change how it interferes with other components) – The Photon Apr 19 '20 at 16:49
  • @ThePhoton The comment says that it's important _not only in production but also in service. Especially for equipment that must be able to tolerate shock and vibration, rigid cable ensure the cable routing stays exactly where it should_. That is what I already understood from your answer. I was talking about that, but I deleted the previous part of my comment by mistake. – Toothbrush Apr 19 '20 at 16:58
  • @Toothbrush, I edited at one point to include Neil's comment. I think J had made his comment before the edit. – The Photon Apr 19 '20 at 17:00
  • @ThePhoton I guess that explains it. – Toothbrush Apr 19 '20 at 17:03
From a mechanical point of view, a rigid (or semi-rigid) cable has the advantage that they will support themselves. That means that you don't have to worry about them getting pinched or stuck between things when they shift or move during assembly or transport.
A rigid/semi-rigid cable also has performance advantages. As it doesn't move or flex or vibrate, the electrical length will be more stable over time than with flexible cables. This can be important in applications where length matching or calibration is important, and is one of the reasons that test&measurement equipment is full of these rigid sections.
As others have said, you will have these manufactured by your suplier (or inhouse) to the exact shape and bends you need.
From an assembly point of view there is another advantage: they can result in fewer errors (but I don't think this is a significant factor when choosing for them). As they are made to the exact size, they will usually only go in one way, and you can't by accident connect to the wrong port within the device.
I think they might also be cheaper at high frequencies, since the solid nature of the outer conductor is easier to manufacture than the very tight weaves needed for coaxial cables operating at many tens of GHz.
Joren Vaes
  • 12,376
  • 64
I expect the isolation is also better, and the crosstalk is lower. Thus your ultimate system dynamic range will be better, which may be crucial for battlefield survival or to detect more planets around red dwarfs
If you want a system that will NOT outgas from plastic cable coverings, the volatiles not being set free to condense on your billion dollars of optics, or condense on relay contacts, then semirigid or rigid is your friend.
Also the rigid may use very sparse spacers inside, allowing mostly air/vacuum as the dielectric and thus LOWER losses.
analogsystemsrf
  • 33,703
Lower passive intermodulation, phase stability, and better shielding. Lower insertion loss, better temperature range, better dielectric and ... just everything.
But notice that your reference url shows a device in which two of the original semi-rigid cable assembly parts (W4 and W5) have been replaced with colorful flexible coax: flexible coax is available in better grades than it was when the 8445B was new.
david
  • 4,364
  • 30
