What is the purpose of R40....R45 and pull-up resistors R46....R50 on SDIO lines as shown below? enter image description here
Is it really necessary to have L51, C52 & C53 matching circuit for antenna?
Lalit
The pull-ups are there to prevent a floating bus and their resistance range is mandated by SD interface specs. SD cards start in open-drain mode so it would not work without them.
The series resistors are there to limit signal rise/fall time. It acts as source termination for driving the bus, and by reducing the bandwidth, there is less ringing and over/undershoot on the wires.
Justme
  • 127,425
  • 261
R40-R45 are 22 ohms, right? Then they're probably what's called source termination, or back termination resistors. Their purpose is to try and match the output resistance of the driver (maybe 30 ohms?) to the 50 ohm trace impedance. 30 ohms + 22 ohms = 52 ohms, which is what a reflection coming back from those lines see. So if the traces are nominally 50 ohms, you get little or no reflection from the "right" side of those resistors.
Here's an example, where the driver output resistance is 10 ohms, and so uses 39 ohms to get a good match to the 50 ohm tranmission line.
Also, look at this post:
What's the importance of source impedance termination?
SteveSh
  • 9,672
