I have a question about calculating the admittance between buses in the single line diagram shown below:
The solution I have been given shows that the admittance between bus 2-2 is found by adding the admittance between bus 2-5 and bus 2-4. Is this correct?
Why do we need to be calculate the admittance between bus 2-2? I thought we would only require calculating the admittance between different buses?
Thanks
David777
  • 1,548
  • That is correct if you are talking about the on diagonal element of the bus admittance matrix. Otherwise, I don’t understand your nomenclature (bus 2-2) when compared to the drawing – relayman357 Apr 11 '20 at 13:33
  • @relayman357 Yeah I do not understand it either. I will add an answer to the post if I manage to get it sorted. – David777 Apr 11 '20 at 18:37
0 Answers0
