I got this question because the creepage and clearance distances need to be adjusted for altitude. The higher the altitude, the higher the distances should be. It seems to me however that the contrary is true. What I mean is that we can tolerate lower distances because vacuum is a better isolator (if not the best) compared to air.
So, why does the overall medium resistivity/breakdown voltage decreases with altitude increase?
jusaca
  • 8,749
  • 58
HatimB
  • 826
  • Note that this is the principle on which gas discharge lamps operate, whether mercury or neon, and also those "plasma ball" toys. – pjc50 Apr 09 '20 at 10:54
The behaviour is described by Paschen's Law.
Electrons are accelerated in the electric field between two electrodes. If there are gas molecules in the path of the electron it will collide with them with a certain probability and it transfers some of the energy to the molecule.
The longer the statistical distance between two collisions is, the longer the electron can be accelerated in the electric field. Only when the electron reaches enough energy to ionize the molecule an arc can be produced.
Lower air pressure -> less collisions -> Longer acceleration and more energy in the electrons for ionization.
At some point the pressure reaches almost a vacuum, then the breakdown voltage starts to increase again, because the electrons don't hit any molecules they could ionize.
jusaca
  • 8,749
  • 58
    Okay, so electrons are like street racers. We don't worry about street racers in a bumper to bumper traffic jam, but on the open freeway, where they dodge and weave freely among cars, the collisions they can cause are severe. – Kaz Apr 08 '20 at 21:14
  • I guess that comparison is fair enough, yes. – jusaca Apr 09 '20 at 05:57
You probably ought to look up Paschen's law: -
Paschen's law is an equation that gives the breakdown voltage, that is, the voltage necessary to start a discharge or electric arc, between two electrodes in a gas as a function of pressure and gap length. It is named after Friedrich Paschen who discovered it empirically in 1889.
This follows Paschen's Law - basically at low pressures gas stops acting as a fluid, and ionization (mostly of Nitrogen) starts to become a problem.
Wikipedia explains it in some depth: Paschen's law
The rough rule of thumb is that it maxes out at pressures of around 0.1 atmospheres.
Yellow Yeti
  • 59
