So how negative can I drive the Vgs of an N-channel Mosfet before damage occurs? Datasheets specify BVDSS and BVGSS but these are "forward" breakdown voltages -- ie the absolute maximum Vds before avalanche breakdown of the drain body pn junction, and the maximum gate drive voltage before the electric field breaks down the gate oxide. I can't find the "negative" breakdown voltages in the device specifications.
Does the susceptibility of the gate oxide to an excessive e-field then suggest that the maximum "negative" Vgs is the same as the BVGSS specified but in the opposite polarity?
EDIT: Here's a portion of the p-channel device I was looking at that prompted the question: enter image description here
jrive
  • 616
All datasheet specified Vgs_max for example.
In this case "negative" (minus) 20V is the maximum value.
G36
  • 13,642
  • yep, it is obvious from that data sheet, thank you. The datasheet of the device I was looking at (a P-channel, CSD25213W10) does not specify it... Unfortunately, I can't add the pic here... It specifies it only as BVGSS Gate to Source Voltage; VDS = 0V, IG = –250μA –6.0 V (min) I asked the question in terms of an N-channel to avoid any confusion, knowing that i would understand how any given answer would apply to the p-channel device. So, although the datasheet for the CSD25213W10 does not specify the maximum reverse Vgs, it is then understood to be +6V? see updated question question.... – jrive Apr 06 '20 at 19:16
    Yes, it will be +6V because if the MOSFET substrate was not short together with a source (due to physical construction) it will be a fully symmetrical device. – G36 Apr 06 '20 at 20:21
